**TOOL NAMING CONTEST**
CLICK HERE to enter the contest.
Re: **TOOL NAMING CONTEST**
I've been playing with tool for a couple of weeks now. It is a wood eater and very controllable and easy to use. It leaves a surprisingly clean cut considering it's more or less scraping however when your hollowing a bowl and using the 9 oclock position of the cutter I believe it may be cutting since it leaves a very smooth finish.
I'm still new with it so I can't offer much more than that. I'm sure I'll know more about how it handles in the next few weeks. So far I've only used it in scraper mode because that's how it was designed to be used. (except for the bowl side cut I mentioned) I will be doing some bevel rubbing cuts on the next project to see how that works and if there are limitations.
I'll be interested in the names you come up with.
steve worcester
It is actually cutting since the cutter isn't flat topped. It would be the equivelant to using the nose of a gouge with the flute straight up.
It's a great tool though. Hopefully we will get them in time to have at the symposium
JerryW
Looks like an adaptation of a negative rake scraper to me.
Jerry Wright
steve worcester
Kind of. Last year I started to develop a NR scraper using carbide and there just isn't a lot of square polished carbide inserts available. I gave up and talked to Doug Thompson about modifying his V10s angles for that use. I think at the Symposium this year and a few to follow, it will become the rage. They are a real useful tool, but carbides not there yet
JerryW
Negative rake scrapers have been around a long time and are pretty easy to make. I have ground a bevel on top of round nose as well as straight scrapers. They perform very well when cleaning up tear out with fine cuts, but can also be quite aggressive if pushed.
Now back to the tool naming contest!!!!
Keith Tompkins
keith tompkins
The Hunter "Monster". That was easy! Thanks, if you need my mailing address, let me know :D
Steven Antonucci
A skew is a negative rake scraper
steven antonucci
If presented as such.
I occasionally use mine this way, and they leave an excellent finish.
S
Doug Thompson near Cleveland
Wait "Boss Hog" might win but I can't play...
Mike Stafford
Mike Stafford
Mike sent me a couple of these tools to use in my class this past week.
We used them for rounding up small face grain box blanks and end grain spindle oriented blanks and the tool worked like a charm.
I provided woods such as myrtle, magnolia, ambrosia maple, ash, walnut and hard maple for the class to use and it responded favorably to them all.
This tool will take the gnarl out of gnarly and the tears out of tear out. I was very impressed at how well it cleaned up end grain tear out on some very soft magnolia that was beginning to spalt. Properly presented it cuts beautiful little curlies off blanks and will take a blank from roughly sawn edges to smooth as silk finish. It responds well to speed as do most carbide cutters. The massive shank takes all the vibration out of your rough turning efforts.
It will also cut composite and acrylic pen blanks with ease. Mike did a demo one evening and turned a cherry blank round and shaped a hollow globe ornament exterior with this tool beautifully. Several members of the class added one to their tool collection.
I had more time to play with the new un named Hunter tool this weekend. Veedddy interesting. You can rub the bevel, like you would with the #3, #4 or #5. You can use it flat to waste away wood and get the shape close. then tilt it either left or right depending on the direction you are cutting and clean up the surfaces or refine the shape similar to the way you would control the shape with a bowl gouge.
Basically with that one tool I can rough out the outside of the bowl using the cutter flat with the bowl mounted between centers. the turn the cutter on it's right side to clean up and fine tune the shape of the base toward the foot. Turn the cutter to left side and clean up and fine tune the shape toward the lip. While it's tilted to the left I can turn the Dovetail tenon for my chuck and clean up the foot area.
Reverse the bowl and clean up the lip with the cutter flat. Then rough shape the inside with the cutter flat. then I tilt the cutter to the right and make a few clean up passes and fine tune the shape. All with one tool.
You do have to be careful not to use the 3 oclock and 9 oclock position on the cutter when it's flat. You can buy you need to take very light cuts. It can self feed and grab the wood. If you need to clean up the inside lip for example with cutter flat, move the handle around and use the 11 to 1 or 10 to 2 position on the cutter.
I'll do a video eventually. I want more playing so I really understand what it will do.
Mike Hunter
Mike Hunter
A huge THANK YOU to the members of WoodCentral. There were many creative suggestions which made it difficult to narrow down to one choice. The winning name is �The # 3 Hunter Hercules Tool.� The name Hercules has instant name recognition and in use, the tool does have many of the attributes of Hercules.
The winner, also the early entry of the name, is Rob Wallace. I understand that Rob will be at the AAW symposium and will bring the tool for delivery on Sunday.
Steve Kubien
Steve Kubien
Excellent name. Well done and congrats Rob.
Galen Vetterick
Congratulations Rob! :D
By the way, we now expect a demo of this tool at our next turners meeting!
A hands on meeting would allow us ALL to break it in for you.
Fred Bearman
It was fun, and I'm looking forward to being able to buy one of these puppies!
