Jumbo jaw extensions
This is another adaptor I've been planning to build. I drilled 3/4" steel rod and tapped both ends. One has 6mm threads. I put 6mm bolts through the jumbo jaws and screw this into the steel. I put 5/16" threads on the other end so I can make adaptors as needed to hold those really weird shapes. One adaptor that I plan to make will be some 1 1/2" circles with the hole off center so I can adjust them even further for wierd pieces.
Re: Jumbo jaw extensions
mjonesrdg
Like these! Recommend large flat washers on the back side.
