Mounting a burl
Mounting a burl
Mounting a burl
I always want to do things a little different. I had this burl for years and when I was getting ready for my mounting wood on the lathe demo this weekend in Chattanooga I decided it was time to mount it so can turn it the way I want.
I used a profile gauge and in some cases just cut the wood close and them fined tuned it by trial and error. then it is hot glue like crazy. Use as many stabilized braces as you can. I have done this several times with no problems but since it's glued to the bark in this case I will use the tailstock until the last possible moment. And I will be wearing a face shield.
After I mounted the burl I knew it would not be perfect so I place it and the wooden backing plate between centers and adjusted the backing plate center until the top of the burl was in the position I wanted. Then I turned an opening in the backing plate for my chuck. The backing plate will be wobbling a little, I did true up the outside on the bandsaw.
I will turn the top face and a bowl depression. Then I will go back and turn the outside possibly leaving some bark here and there. I'll play that by ear when I turn it.
Re: Mounting a burl
Rob Wallace
Re: Mounting a burl
Rob Wallace
John -
I like the idea of individual supports contoured to match the shape of the burl....Questions: Is the burl glued to the contoured edges? If so with what kind of glue? Hot melt? CA? PVA? Are the radial supports screwed to the backing plate?
Great idea!
Rob
Re: Mounting a burl
Re: Mounting a burl
Rob Yes, I put hot glue on the contoured side of the wood and at the same time put glue on the flat part. Then I slide them in place. Once the glue hardens I put more glue anywhere I can to get a really strong joint. I'm going to turn it all away later so it won't matter.
I think epoxy would work but you would have to thicken it quite a bit to make it stay where you want. I doubt CA glue would fill the gaps properly.
Another thing I've hear would work is to turn a depression in some scrap wood, pour melted wax in and then place the piece to be turned in that. I'm not sure how you would get it to release. Probably a heat gun and a lot of patience to get the wax to melt again. I believe that would be much more solid than what I did.
Re: Mounting a burl
Steven Antonucci
Certainly want to see a video of that spinning!
steven antonucci
Re: Mounting a burl
Re: Mounting a burl
Myra in TN
Where and when will you be doing this demo in Chattanooga this weekend?
Re: Mounting a burl
Re: Mounting a burl
Here is where it is.
6526 Harrison Pike, Chattanooga, TN. http://tristatewoodturners.org ...
I believe the meetings start at 1 eastern time. I'd be glad t meet you somewhere along the way to help you get there. I come down 111 to 127 and then go across the Chicamauga Dam. I usually meet a couple of guys for lunch at Logans before we cross the dam but I haven't heard from them yet. You would be welcome to join us.
Re: Mounting a burl
Our department is going to a video class tomorrow
I've also just ordered my new Mac with Imovie11 so maybe I can learn how to do this right and do it at home instead of staying late at work and not knowing what I'm doing.
I don't have a high speed camera to capture it when it dismounts however. :)
Re: Mounting a burl
Re: Mounting a burl
Myra in TN
Thanks for the info and the kind offers of help. I don't know if I can make it but I will definitely try - I know where that address is. VERY new to turning but I've been lurking around trying to learn things. I hope to see you there.
Re: Mounting a burl
Re: Mounting a burl
Myra I talked to Doug Spahn. He and Charles and I will be having lunch at 11:30 at Logan's Roadhouse on Gunbarrel rd. (hwy 153 just before you get to the dam from the west side) I'll treat you to lunch if you feel like sharing the company with 3 crazy woodturners.
Re: Mounting a burl
Re: Mounting a burl
dick gerard
John
How do you get the hotmelt glue off th outside of the burl?
Re: Mounting a burl
Re: Mounting a burl
Dick In this case I'm going to most of the outside and don't plant to leave the bark on. On pieces where I've turned the outside and used braces to support it I use what resembles a wire burning tool or Garrot to sort of saw through the glue joint. Then I rub off what I can and use alcohol to remove the rest.
It's very successful on smooth surfaces. Don't know about a very porous wood. I also put some sort of protective finish on before I hot glue because the glue residue can impair new finish.
Re: Mounting a burl
Re: Mounting a burl
Charles Jennings
John, your presentation at Tri-State this past Saturday was great. It including mounting burls and pieces of all configuration that was of great assistance to all that were at the meeting. Thanks for the great job you do in sharing your knowledge and experience to the woodturning community at large.
Re: Mounting a burl
Re: Mounting a burl
Roger A Crooks
This was a timely posting. I just have an 8" maple burl cap and rather than turn it normally with a natural edge, I want to use the cap as the outside of the bowl. I've searched the internet for ideas and pictures of other turnings like this but did not find much. Mounting is the obvious issue. Since I will need a base for the bowl, I'm thinking of finding the center the best I can (it is not exactly round) and drilling out space for a 2" faceplace which will be the attachment point for some kind of base.
Any ideas, advice or pictures of similar type turnings would be appreciated. Also ideas on finishing the burl cap. I've used an air hose and brush to clean it up but when done, best idea I have now is to just dip it into something like Danish oil and leave it at that. Nice to not worry about sanding :-)
Re: Mounting a burl
Re: Mounting a burl
Myra in TN
I thank you for your offer. However, I was not able to shake free of my prior obligation so I had to be elsewhere and just now got back to the message board. I'm going to get in touch with the people locally who run the meetings and find out the schedule of their meetings. Thanks again.
Re: Mounting a burl
Re: Mounting a burl
Myra There are two clubs in the area of chattanooga. The Dalton area woodturners and the Tri-state woodturners. The Woodcraft store can give you information on both clubs if you have trouble finding club representatives.
