Burner tip question
Burner tip question
Steven Antonucci
Burner tip question
steven antonucci
For those of you using wire burning tips in your pens, have you ever accidentally touched across the two terminals with the current flowing?
I am just wondering if there is a shock hazard moreso than a burn hazard?
S
Re: Burner tip question
Steve can't answer for sure and don't really plan on laying my fingers across there to find out. What I can say is electricity takes the path of least resistance. I would think the wire, even Nichrome wire which has some resistance, will have far less than your finger. I don't know, that's a guess.
Steven Antonucci
I was adjusting the tip with insulated pliers
steven antonucci
and they were buzzing in my hands. I agree that you'd likely get burned before shocked, unless your pliers had a cut in the handle...
S
Re: I was adjusting the tip with insulated pliers
I think steel pliers would have a lower resistance than the Nichrome.
Rob Wallace
Rob Wallace
Steve:
There would be far more of a burn hazard than a shock hazard. The woodburning controllers (woodburning "machines") produce low voltage at fairly substantial current. You would probably need to set-up a deliberate shock hazard if touching the pen parts, and by the time you did this you would be screaming from the burn pain!
BTW - don't ever short-out the nichrome wire tip with a conductive metal (i.e adjust it with pliers while current is flowing) - you would be asking for a major melt-down of the connecting wire, if not worse - hopefully a fuse or circuit breaker in the power unit would shut it down before something catastrophic happens.
Rob Wallace
steve worcester
Ditto what Rob says. Essentially, laying a piece of Nichrome across the tips IS shorting it out, The results is the glowing wire. You would definitely feel the heat before the shock, maybe unless you have a pacemaker? But you don't typically touch the glowing wire, or use the burner in the rain or shower.
Why do you ask?
Steven Antonucci
brain fart
steven antonucci
I was tweaking a shape with the juice still flowing and the pliers were buzzing in my hand. Just wondered what might have happened if i had reached for the leatherman instead...
Dick Hines
Re: brain fart
Dick Hines
I make my handles like to older ones Molly used to make. I turn a bead on the burner end so my hand will not slip onto the burner tip.
I don't want to find out first hand , shock or burn?
It's not the voltage, it's the AMPS
steve worcester
So, most power supplies for these aren't going to harm you much. Probably less than touching live 120V. Might damage the power supply, but if it is fused, worst case you have to =replace the fuse. If the pliers are insulated, you won't feel it and there won't be damage other than the power supply trying to heat up the pliers too.
Steven Antonucci
If it is the Priddle burner (Car battery charger)
steven antonucci
might be a few more amps, huh?
S
