How to center earth magnets in a top and bottom
Barbara Dill
I've never used earth magnets. I do think using earth magnets will help me with a teapot and it's lid. The pieces must be lined up exactly so that the top and bottom are in line with one another. I need advice. Thanks
Re: How to center earth magnets in a top and bottom
Steven Antonucci
First thought- one magnet, one bit of steel
steven antonucci
To avoid having polarity issues. Two magnets is probably overkill.
S
I'm having a senior moment and can't remember the ladies name who does the celtic knot pieces. She makes boxes and imbeds a very small rare earth magnet in the the lid and base to keep the lids aligned. I believe they were around 3/16". She would drill a hole, glue the magnet it, and then fill the tiny gap above the hole with sawdust from the piece. That didn't totally conceal the magnet but made it far less obvious.
She cuts a rabbit for the lid into the top of the base. The rabbit has a 1/4" shoulder so she can drill straight down into it. of course on the lid she drill up into that. I don't remember where she got the magnets. I bought 1/4" ones at Radio shack once.
Dave Belser
You didn't put to many constraints on what you have and where you are at - so here are a few ideas, based on my experience
If the work pieces are still chucked or can be chucked and determined to run very true, I would use a cross slide that I have that bolts to the lathe and allows me to hold a drill precisely. I assume you don't have such a setup so here is an idea for doing it without one.
Use a box making tool rest (flat tool rest) and cut a block of wood that's maybe 1/2" thick. Drill a small hole in it and set it up so that the hole is center on a tailstock mounted center and the block rests on the tool rest such that it's basically level. You would need to get the boxrest height just right. Once this is set don't change it.
Drill another hole in the block at whatever distance you want the magnets to be from center. Make it the same size as the holes needed for the magnets.
Now you can mount your work, use your indexer settings for however many magnets you want to use. Set up the drilled block and boxrest using the tail stock to find the center for the block and drill your holes through the other hole in the block.
Probably sounds a little more complicated than it is.
Another approach would be to drill the holes something like above but just measure from the center. Make the holes a little over sized for the magnets. Then use epoxy to glue the magnets in place - but cut open a sandwich bag and put it between the top and bottom with the magnets stuck together on either side of the plastic. Put the lid on and get it lined up just how you want. When the epoxy is cured, you will be able separate the lid and pull the plastic off.
If you are careful the magnets should be perfectly aligned. You may need to scrape a little epoxy off.
Hope the ideas help.
- Dave
Best source *LINK*
Dave Belser
That I've found is K&J magnetics - www.kjmagnetics.com
Huge selection, great prices and nice folks. You can get some really tiny magnets from these guys. You don't need very big ones as they are quite strong.
http://www.kjmagnetics.com/
BillTurpin in WNC mountains
My then 17 yr old grandson asked me help him make a wooden locket for his girlfriend. No picture available because she will not take it off! We could not find a hinge or latch small enough. We glued two thin pieces of Bethlehem olivewood (she is very religious) with kraft paper and Elmer's glue. He then turned, carved, machine and hand sanded a heart shaped locket. He separated the halves so that a picture of them could be inserted later. The heart is about 1" in diameter and 3/8" thick.
Very small magnets (4 sets of two) with a maximum pull were used. We got the magnets from KJMagnets. They were 1/8" x 1/16". They had to be light enough to be worn, but strong enough to simiulate a hinged piece of jewelry. The pull strength is a combined 2.5 pounds. A four hole inside drilling pattern was created on my computer and was flipped electronically for the other side of the inside. Magnets were sanded to create grip for CA glue. Holes were covered with olive sawdust/CA and sanded smooth. Pick-up tools were made with small sticks with KNOWN polarity magnet exposed. These small guys are very slippery and will flip their orientation in a heartbeat. Order extras, because you will loose some and never find them! Opposite polarity pick-up sticks were made for the magnets on the other side. There was NO allowance for a mistake.
The locket has been worn successfully and constantly for seventeen months . There is a hanging screweye in only one half. These small but strong magnets can be snuck into all kinds of projects. The magnetism will pass THROUGH your hand and can make some amazing and spooky projects! These disc magnets are available with the poles on their faces or on the edges. Be sure you order proper orientation for your project. Be careful: larger ones(~3/4") can pinch or cut skin if mis-handled. If you order small ones, you will spend as much for freight as for the magnets. These magnets are brittle and will shatter if dropped on hard floors.
Have fun, Bill
home made drill guide
Barbara I'll post a photo of my homemade drill guide when I get home tonight. That will make drilling the holes very accurate.
Barbara Dill
Very helpful. I have lots of ideas now. I know Louise Hibbert uses magnets in her work, but never paid much attention. Wish I had. Thanks a lot!
Ditto on KJMagnetics
Richard Jones
Nice folks
Sharon Doughtie
HeatherAinAK
Peter Rand
Hi Barbara - I use magnetic closures on my femisphere boxes (get them from "gaussboys" on the web 10mmdia) I embed one on one side, CA'd into a drilled hole and then covered with veneer which hides it completely. Then its mate adheres to it thru the veneer and when you align the two pieces it tells you exactly where it should be on the other piece, and so where it should be similarily embedded. They are strong, even thru veneer, so the idea of just a piece of metal may be enough.
Drill guide
Barbara Here is the drill guide I use on the lathe to drill straight or angled holes. Just make the holes in the side whatever size your drill bit is. I drill the holes in the square side on the drill press. As you can see in the photo mine has several holes for different drill bits.
It was Sharon Doughtie who did the box demo with magnets. She gets her magnets from forcefieldmagnets.com She uses 1/4" magnets. I think she used 3 set 120 degrees apart. If I remember correctly she stepped this off with a set of dividers and just did a trial run or two around the box adjusting the dividers until she got 3 even steps. I use an index wheel, simply because I have a couple of them.
redrx793 gmail.com
Try at set of these dowel pins. http://www.generaltools.com/DOWEL-TENON-PINS-D_p_216.html
I use them when I make boxes with pivoting lids. Drill a hole the same diameter as the magnet, usually no larger that 1/4, insert the dowel pin, align the lid and apply sufficient pressure to mark the bottom of the lid. Lastly, use the reference mark to drill the hole for a matching magnet or metal pin of the same diameter.
Barbara Dill
Great ideas and very helpful. Thanks so much.
