Carnac the Magnificent
GaryG in MD
And the answer is.... "wood bleach"
For a change, I decided to post an answer instead of a question.
Ever since seeing Betty Scarpino demonstrate, I've been wanting to do some bleaching. Unfortunately Kleen Strip has stopped making the reasonably sized two-part wood bleach kit (quart-size containers) and is only selling in gallon size for the ridiculous rip-off price of $120/kit. No way.
I looked at the MSDS and found that their part A is nothing but a weak lye solution (3-7%), and Part B is a relatively strong hydrogen peroxide (25-30%).
I went to the hardware store and got a pound of Rooto 100% lye drain cleaner crystals for $8. This is enough to make many, many gallons at the 6% (by weight) concentration that I chose to make. [Do not use Drano which has other chemicals and aluminum slivers in it -- make sure it says "100% lye".] Beware: this stuff is extremely hydroscopic -- it has to be kept very dry and can be dangerous if you get it wet in the container. It is also exothermic -- it gets very hot when you purposely mix it with water. It is highly caustic. Take proper precautions and wear eye protection.
I went to the pool supply store and got a gallon of Baquacil swimming pool oxidizer for $18. It is 27% hydrogen peroxide. Perfect.
My total investment is now well under $30 for enough of the two needed chemicals to last me a lifetime.
I mixed up a pint of 6% lye (6 grams per 100 cc water) and stored it in an old glass reagent bottle I had laying around. Plastic is ok -- do not store in metal. It keeps indefinitely.
I mixed small, equal amounts of the lye solution and the Baquacil in another small glass jar. I used a Q-Tip and tested it on some red oak and walnut -- just swipe it on to wet the wood, and let it dry.
Works like a champ! Great results. One coat does a pretty good job. The second coat makes it better. I didn't try more.
Just sand down the raised grain with some 320 sandpaper and maybe take it up to Abralon 1000 to put a little sheen on it. No finish is a good finish -- or some Ren Wax; maybe some clear fixative. Most finishes will yellow it, and you don't want that.
You have to mix the two parts freshly every time. Throw away your excess (in a responsible manner) when you're done applying it because it goes bad quickly -- I tested the mixture after 24 hours, and it was no longer effective.
Give it a try! ...Gary
