ca what if question
ca what if question
ca what if question
avalon
So last week i made a hollowform that i attempted to fill cracks in with copper and then dripped ca on it... the ca stained the ambrosia maple in large areas...
then someone told me to put sandingsealer on before i did that again..
However, This weeks project is another hollowform that is starting to show tiny cracks and also has bark still around the rim of the opening..
so do i put sanding sealer on the bark before i stableize it with ca, or ?
Re: ca what if question
I just put some of whatever finish I'm going to use on the wood so the CA won't stain it. Then I coat the cambium layer with thin CA. I try not to get any on outer bark. What your trying to do is firm up the inner bark or cambium layer. This area can be hard to cut cleanly because it's so soft. The CA also act like the glue that it is and helps keep the cambium layer from separating from the wood.
Dick Hines
Dick Hines
If the checks and cracks are small most times they will close if you just let the piece sit fro a day or so.
cracks will often close up but they are still there. I had a piece of Bradford pear and as a test I cut a 3" section of limb off. I sliced 1/4" thick pieces off the end and layed these on my work bench. The thin slices stayed intact, pith and all. The thick piece started cracking after about 3 days. The biggest crack was about 1/6" and an inch long.
After 2 weeks the cracks closed back up and you couldn't see them. Yesterday I sanded the end to 400 grit and guess what. They are still there and show as very small radial lines. At this point you would have to ask yourself if that bothers you. On a high end piece it would both me and make it trash. However on a lower end piece cracks this fine would not bother me. Larger cracks that still show would unless it doesn't hurt the functionality of the piece.
so what did this tell me. In Bradford Pear you can leave the pith in if it's turned thin. Especially if the pith area is not flat. The slices off the limb would usually be a worse case scenario. If you make the same slices cone shaped it will usually crack less because it will warp more easily and relieve the stresses.
