Re: Chinese Balls
Fred
I have no idea of what they are or how they were used. They appear to be cast, probably brass or bronze. The hole configuration is that of the Chinese Ball with 12 equally spaced primary holes. The knobs appear to be located on the 20 auxilliary positions (the center point of each of any three primary holes, which form an equalaterial triangle). I doubt that there were other balls inside as is the case with the Chinese Ball.
I saw an Ivory Chinese Ball with 13 balls, with each ball intricately carved. I often wonder how the Chinese made these balls without lathes and the modern tools. At this point, I've only been able to make Chinese Balls with up to seven levels using the tools that Christian Delhon of France was demonstrating and selling a couple of years ago. I purchased a set of his tools, which will make a seven ball Chinese Ball. Unfortunately, Christian has decided to quit making them.
If you belong to the AAW read my article in the June 2011 issue of American Woodturner. It tells how to make the five level Chinese Ball using the Crown Tools.
