Hey Randy G... you know I'm going to make this!
steven antonucci
Grinder hot-rodding... I am in love.
S
steven antonucci
S
Re: Hey Randy G... you know I'm going to make this
Randy Gleckler
We've never met and I can almost see your mind kick into high gear on how to make that just to see how it works. Will have to see pics. :-D
I'll stop by Alan Z.'s place first, since he has 1
steven antonucci
I have a 1HP motor laying around looking for something to do...
And a buddy who is sort of a machinist...
And Alan's close enough for a drive by to take some pictures.
Yeah...it's going to happen!
S
They just had a workshop at the craft center on building a knife sander. I could not go. The class was $300 and the material cost was $900 to $1,300. I'm pretty sure I can build one for much less and will sometime soon. I've been needing one and just need to sit down and design it, find the parts and start working.
I've done the same thing I can do with a Knife sander with a set of hand files. I've used those for years. But now that I've had a taste of how fast you can work with a sander I'll switch as soon as I can.
Re: Hey Randy G... you know I'm going to make this *LINK*
Michael Mocho
Hey Guys,
After seeing the video of the abrasive belt attachment for the grinder, I thought you may find this idea potentially useful:
I have been using my lathe to drive an abrasive belt over a shaped wood block that is held in the tool rest base. It is a very simple attachment to make, and it�s been a great tool for sanding wood or grinding metal, especially since it is variable speed.
The drive drum is turned from maple, has a slight crown to keep the belt tracked, and should be covered in rubber for belt traction, since the bare wood is too slick- (a piece of motorcycle inner tube works well, or it can be wrapped in a long strip of rubber with contact cement. I have also used electrical tape when I have cobbled one together when out teaching.) The left side has been turned down to fit the #2 Morse taper of the lathe spindle throat, but it could also be threaded or mounted on a small faceplate. The live center of the tailstock supports the drum after the belt has been slipped on.
Tracking the belt is a matter of adjusting the tool rest base so the belt is in tension- do this as low RPM, then bring up the speed for use once you are certain the belt isn�t crawling one way or the other.
The platen block can be flat or bandsawn / disc sanded to just about any curve, and a turned post is bolted to it to fit your tool rest base (banjo). The key to the system is covering the block with graphite canvas- it reduces the friction that would turn the thing into a smoldering mess if you didn�t have it. I by it by the yard in different widths, and simply staple it to the shaped wooden block over a thin layer of cork, which provides a little cushion to the sanding action.
You can get graphite canvas from many places- including Klinspor, Woodworker�s Supply, Econ Abrasives, and many other suppliers. Here are a few links:
http://woodworker.com/4-wide-graphite-canvas-mssu-919-610.asp?search=&searchmode=2
http://www.woodworkingshop.com/cgi-bin/480D01D2/mac/qryitems.mac/itemDisplay
I use the 4 x 24 belts that fit my belt sander, but I don�t see why you couldn�t adapt the design to other belt lengths and widths.
The idea started as an attachment I made for the drill press- using a rubber drum in the chuck to drive it, and the platen block was simply screwed to a piece of plywood and clamped to the drill press table to tension the belt. Tracking was done by driving a wedge under the plywood to tilt the block, It worked wellm but tied up the drill press, so I made a self-contained machine out of a washing machine motor in a plywood box and a simple tracking mechanism with a quick-release belt tensioner to changing belt from roughing to polishing was easier. I can also use it in different positions by clamping the thing in my bench vise as different angles so I can shape with the belt running at the most convenient angle to the work.
The motivation for making this attachment for the lathe was to demonstrate abrasive carving techniques when I am out demonstrating, but I have found it useful for all sorts of tasks in my shop, including grinding and polishing metal for tools.
Hope this helps,
-Michael Mocho
www.mmocho.com
Photos of the sander attachment can be seen at:
http://mochofinewoodworking.shutterfly.com/pictures/8
photos of sander attachment for lathe
Plans for a grinder
Jim B
Detailed drawings and pictures for a KMG grinder are posted at http://www.dfoggknives.com/PDF/GrinderPlans.pdf. Google KMG grinder for more info. I've built one several years ago - you will find many uses for one other than knife grinding.
Alan Zenreich
John,
I have a Bader III belt grinder. If you need any close up photos for inspiration I'll be happy to make some for you.
I have both an 8" wheel, and a two wheeled "knifemaker's platen"
Alan Z.
Randy Gleckler
I saw Michael demo this sander in Nashville this year and for a Demonstrator I could see it being invaluable, for a home shop, it's just plain Cool and amazing. I haven't had a chance to build one yet, but I keep thinking about it and plan to. Such a great idea...
That's pretty cool. Now if you can just make it oscillating.
That's another sander that is on my list.
I have to work Saturday but I'm going to try and drive up to Crossville for a few minutes just to say hi.
Haven't gotten around to this one yet...
steven antonucci
but it was also on my list since you showed it to me somewhere (WGW or a symposium)
Coolest thing I ever saw...
S
Very Cool Michael!
Don Orr
I've seen this attachment in action and it is outstanding ! Michael was one of the best demonstrators I ever saw (at Totally Turning a couple years ago).
charlie belden
If you don't have the stuff to make things out of metal, you often can make something that works out of wood - or plywood.
The attached long belt sander, that Michael Colca, a furniture maker near Austin came up with, uses the graphite impregnated fabric mentioned in this thread. Does require a lathe to turn the pulley on the motor end - but the rest ain't a big deal to make.
I particularly like his simple Belt Tracking Adjustment.
