Have a question? Ask Woody!
cyanoacrylate issues
avalon
I bought a cube of ambrosia maple from woodcraft the other day..
started turning and it got a crack from top to bottom... not big, but noticable...
so i've wanted to try to fill a void with something other than sawdust, so i took some powdered copper and put it in the crack, and dripped some ca on top...
it spread all over the wood and has kinda stained it.. also it's HARD... gouges wont cut it when turning..
so can i sand it out, buff it out, use ca remover, or am i stuck with the stains?
Re: cyanoacrylate issues
Sean Troy
You should be able to turn it away. Take light cuts at a slightly higher speed. Sanding will also work. Keep your speeds around 200RPM so the wood doesn't heat up and sand in a circular motion as the wood spins. Very common problem. A way to avoid it is to spray sanding sealer on the wood before you use CA to fix cracks. Sanding sealer doesn't penetrate the wood much and sands away very easily.
Ric Taylor
Ric Taylor
In this case, you are probably stuck with the stains. Next time, put some lacquer in the crack first. It will dry quickly and seal the walls of the crack. Then when you put the CA in the crack, it will not penetrate the wood, which is what causes the stains.
CA turns and sands easily, with a consistency of hard plastic. However, over time it will get harder and more brittle.
Ric
Ricc havens
Ambrosia maple is caused by the ambrosia beetle. Just tell people you found a piece with staining caused by the rare and hardly ever seen cyanoacrylate beetle :):)
