AC
Dick Hines
I am looking for an AC unit for my shop. The shop is `15'x25' with 10 foot over head. The walls are filled with R19. Along with the over head.
What size AC would keep the shop cool with out working it's self to death?
AC
Dick Hines
Re: AC
Bill Howatt
Can't give you a number but the unit should "work itself to death" or at least give a good run at it. You do not want a unit that cools the room quickly and then shuts off! You want it to take a reasonable amount of time cooling the room so it gets the excess moisture out of the air - this won't happen if it cools too fast and shuts off. Getting the moisture out of the air has a big impact on how cool you feel regardless of the room temperature.
Bill
Re: AC
Dick Hines
Getting the moisture out of the air in Va in the summer is not going to happen. The run off from my house AC looks like a small stream.
Re: AC
Bill Turpin in WNC mountains
How big is your dust collector and does it exhaust outside? A 400/600 cfm exhausting outside is that much more that needs to be added to the shop area. The make-up air has to be figured in. All that 95� make up air, sucked through the cracks, is a SIGNIFICANT Load. The starting electrical load is six times the running load, there is nothing wrong with the AC being loaded, if it keeps up and cycles off a few times an hour. The humidity will be slightly lower with constant running, than intermittant. The AC works the best with a freon temp of ~36�/and a air temp over the coil of ~45�. With compressor cycled off, the freon temp rises to room temperature.
The compressor must cycle off, so that the ice formed on the inlet to the coil, can melt. Freon temp can drop below 32� with poor air flow, t'stat set too cold, or low freon charge.
Wife's shop 12' x 10' x 7.5' with 4" walls and ceiling insulated with pink roll insulation is well cooled with 11K BTU. DC not usually running. DC running warms it up. We are having temps in low 90's this year.
Re: AC
Richard Allen
I use an 11,000 BTU window unit. The shop is 11x20x8 well insulated on one long wall and one short wall. The uninsulated long wall is the house and the uninsulated short wall is double pane windows. The room is shaded. The 3 HP DC generates more heat than the AC can keep up with on a 90 degree day.
Re: AC
Carole Valentine
Dick you have seen the size of my shop. Mine is a 10,000 BTU. I got one size down from the recommend because my shop is so well insulated with no air leaks. Works great. It does work a little more when I have all of the overhead fluorescent light banks on.
Re: AC
Bill Blasic
My turning area is 24 X 36 with R19 walls and R 38 ceiling. I have an 18,500 btu air conditioner installed and in the 5 or 6 years since it was built I think I've only had it on 3 or 4 times. Todays temps to be in the 90's so it might get turned on today. The cooling effect of the new Airshield Pro will probably help keep the heat index down too.
Bill
Re: AC
Dick Hines
My DC is not in the same room as the AC would be. Since I insulated the walls I can tell the difference between the insulated side and the non insulated side. I am running a big box fan now and it works OK until the temps get into the mid to high 90's.
Getting tired of the 3 t-shirt days.
I guess the cheapest thing i could do is like my grandfather used tod in his shop. He would wet the concret floor and run a big fan. Cheap AC
Re: AC
pete labelle
Just remember that cold air falls. If you are punching a hole thru the wall for this unit rather than using an existing window, mount it up high.
Also, besides not running any unnecessary "space heaters" (lights, motors, etc), isolate your windows so they don't warm the shop thru radiant heat. Curtains on the inside, or awnings on the outside.
I love my basement this time of year!
Pete
Re: AC
Dick, My shop is smaller than yours, about 12 x 22 x8' and it is the basement of my house. I have an uninsulated garage door in the end. Several years ago I put in one of the really small AC units from Lowes. I think it is about 6000 BTUs and was less than a $100. I bought it out of season. It's too small, statistically speaking but it makes a huge difference. It does not cool the shop significantly but it dehumidifies and cools somewhat and makes all the difference. The shop went from being unpleasant to reasonably comfortable. I run the DC when I run a tool, not continuously. It does make a difference when I run it a long time as when I am sanding. And I have the AC set up so that it blows directly on me when I am turning. One of the best additions to the shop in a long time.
If you want to jump up to bigger bucks you might look at one of the little split systems like the Mitsubishi Mr. Slim ones.
When my heat pump failed last summer I moved the little AC into my BR window. Slept like a baby.
