Apprentice Crown Revolving Center
Ed Moore in SW VA
The title of this post should be "Mutter, mutter, cuss, cuss!" I purchased the aforementioned revolving center and it arrived today. I noticed a set screw on the side and because I thought that the center was fixed unlike the Steb centers, I loosened it. WRONG! Suddenly the center released and fired across the shop, hitting a steel cabinet. To my amazement, I found the little center on the lower lip of the steel door. To my dismay, there is no sign of the little internal spring. It may have also hit the steel cabinet, but it could have rebounded unpredictably. I must either find or replace that spring.
Warning! Be VERY careful if you loosen the set screw. I would suggest holding the revolving center vertically with the point against the bench and under downward pressure if you choose to do this. Then raise the center carefully.
Ed
Re: Apprentice Crown Revolving Center
Mike Stafford
You'll put your eye out!  Be careful!!!
Mike Stafford
As usual, some smart guy started.......
JamieDonaldson
... taking things apart without benefit of reading the instructions! :D
Peter Toch
How many times do I have tell you not to play with big boy toys! You have a better chance of finding the proverbial "needle in a hay stack" than finding the spring that launched itself with your able bodied assistance.
Email me the approximate diameter of the hole where the spring use to live and I'll bring my collection of spare springs with me to the Thurs. meeting for the demo by "what's-his-name." I'm sure we can save your butt. Bring the revolving center, point, and set screw with you. BTW, do you really think you are the only one that does dumb things? I have spare springs for a reason, to save others...right.
Peter Toch
Thank you Peter.  I will do as ...
Ed Moore in SW VA
requested. The spring must be 1/4" or smaller and maybe an inch long. I'll measure tomorrow.
And I will do a thorough search. Fortunately this area of the shop is not where the shavings fly.
In retrospect, I am darn lucky it didn't hit my eyes. The force would have been sufficient to do damage.
Ed
Re: Thank you Peter.  I will do as ...
Carol Reed, Strawberry, AZ
Time to go trolling with a magnet on a stick. DAMHIKT!
Mike Stafford
If it landed in the tool bins....
Mike Stafford
there is no chance it will ever be found. :b :D
Steven Antonucci
World's smallest jar of snakes
steven antonucci
Ed Moore in SW VA
Carol,
I am about to head for the shop and my focus is on finding that spring. I have considered the magnet-on-a-stick approach. Are you saying that it works?
There are no shavings in this area. But MANY small pieces of exotic wood are piled there.
Ed
Carol, no luck, still muttering.
Ed Moore in SW VA
A larger bar type magnet, like for nails, is not efficient for nooks and crannies. The magnet is not strong enough, much beyond 1/2"-3/4" away.
One trick that has worked for me was stacking small rare earth magnets on the end of a longer 1/4" rod and poking the other end into nooks and crannies. It needs to be real quiet so you can hear the 'snick' of the rod attracting something.
Good luck. It does help to have a general idea of where to look. BTDT way too many times!
Good luck on your PET scan. We're still praying, you know.
