ok.. i'm cheap... sand disk questions...
avalon
wanting to know if those sand master things by sorby (and others of similar design) are worth it, or a sand pad for a drill, or what is best?
And which is cheaper... right now i'm just buying sheets of various grits from lows and tearing pieces off..
and sanding the inside of a bowl that way isnt fun..
where is a good place to buy disks in bulk, can you make a sander yourself and cut disks from sheets? what do you guys do?
Re: ok.. i'm cheap... sand disk questions...
Leo Cuellar
Leo Cuellar
I just purchased a Sorby Sandmaster after having worn out the Craft Supplies Apprentice version of the tool.
I would recommend getting the Sorby as it has replaceable sanding heads in 2'' and 3". There is a micro version of the Sandmaster with a 1" head also. These tools do have a learning curve, but are remarkably efficient for certain types of sanding. On areas that have no complicated details they excel. You will want to restrict usage to forms that do not have wings or voids. You want to avoid too much heat buildup as with any sanding.
You can purchase different densities of foam add on pads to put between the paper and the sanding head. This will save you having to replace the head while you learn how to use the tool should you decide to purchase one. It is also possible to make your own with foam remnants and velcro sheeting. I'll be making some to try on my 5" RA sander as I use it a lot on work that is flatter.
You will also find that the heads for attachment to a drill will also come in handy for those situations where the Sandmaster won't work.
Are they worth it? That's a matter of perspective. They are a sanding pad that rotates with the bowl. They work - but a sanding pad for a drill can work when you aren't running your lathe - you can't say that for the Sand Master.
And which is cheaper... right now i'm just buying sheets of various grits from lows and tearing pieces off.. and sanding the inside of a bowl that way isn't fun.. where is a good place to buy disks in bulk, can you make a sander yourself and cut disks from sheets? what do you guys do?
You can buy a roll (or sheets) of hook and loop sandpaper in various grits from places like the Klingspor shop. You can cut your own discs (punch or hole saw). You can also make your own sander (think of mounting a pad on a wheel on a piece of wood).
I use a sanding pad and a drill. I find that I prefer the drill.
Cyril Griesbach
I have a Sorby Sandmaster.......somewhere. Why you ask? Because early in my turning experience I went to several of the Sorby demos at Woodcraft. As a result I have a number of "gotta have its" lost in drawers in the shop.
So for me it's a drill, discs and mandrels from Vince Welch.
Re: I am with Cyril - call Vince
Steve Criscenzo
Get up with Vinch Welch. Get mandrels and disks. Be sure to get interface pads. They not only improve performance but they save the mandrels.
I use the cheapo drills from Harbor Freight.
Steve
Mike Mills
Mike Mills
1+ on Vince�s disc (I use the blue). http://www.vinceswoodnwonders.com/
I do use Klingspor for most other sanding needs; just never have tried their small disc.
I had one of the Craft Supply and mine gave up the ghost also after about 15 uses. One problem with them (or that type) is that the center of the bowl has very low rpm and you may still hand to sand that area by hand. And of course they are worthless to remove the "stub" from the bottom once you remove the bowl from the lathe.
To me power sanding is much easier. I use a 90* attachment in a standard drill. A good quality attachment should run you about $20 and you can then use your drill to sand with or without it.
Brad Vietje
Brad Vietje
Avalon,
Power sanding with an angled drill is a good way to go. Many use the Sioux angle drill, but I have a knock-off I use the Velcro-topped pads from Packard or Craft Supply, and I make my own 2" disks. I tried power sanding with a regular 3/8" reversible drill, but like the angled sort a lot better.
To make the discs, I went to a local body shop and asked him to add a few boxes of 6" discs to his next order. The disks are German-made by Wurth, and quite high quality. Get the ones without holes. I bang out the 2" discs with a cheap-o 2" or 2-1/8" hole saw with the teeth ground off (and pilot removed). Using a small 2# - 3# hammer and the end grain on a hardwood log, I can bang out dozens of these in a few minutes.
The Wurth Zebra 6" discs cost me about $28/box of 50 about 8 years ago; each one makes 7 smaller discs, with a star-shaped one in the middle, so they are cheep! For example, each 6" disk costs $0.56, so if you get 7 discs out of each one, that would be 8 cents each! Even if you go out and buy a new hole saw, the cost would come out to around 10 cents each in quantity.
Works for me -- you decide.
Safe spinning,
Brad Vietje
Newbury, VT
dick gerard
ditto that. Vince Welch is my go to sanding supplier ... has been for years
robo hippy
Angle drill vs inertial sander, no contest, angle drill is way better, not even close.
As for punching your own discs, I used to, even had access to a clicker press (small table top punch press), but found that buying the discs from Vince was only a little cheaper, and I didn't have the time expenditure of punching out, sorting and labeling the discs.
Vince's Blue discs get best value, and best product in my experience.
robo hippy
Scott Crumpton
Some points on what I use, in random order:
1 yard sheets of various grits H+L paper from Industrial Abrasives.
2 1/4 hole-saw punch with teeth ground off and sharpened attached to a steel handle.
H+L mandrels from Industrial Abrasives. One for each grit.
Various interface pads and/or soft mandrels and some other sizes for special cases.
Neiko 3/8" angle drill from Amazon.
Cutting my own discs from the bulk sheets costs about 5 cents per disc. The material is good, but not suitable for wet sanding. The Klingspore discs, which I started with, are better but 5x the cost. The 2 1/4 hole punch cuts a slightly over sized disc which I like. IA's mandrels are the lowest cost of any that I've found and just as good as all but the high end ones. At their price you can afford to have one dedicated to each grit. The Neiko drill appears to be a knock-off of the Sioux/Milwaukee. You must service the drill regularly by cleaning and re-lubing as none of the angle drills are intended for sanding. Dis-assembly required. I keep two. I still have my original Milwaukee. The Neiko is not as good, but performs well for this use. They are expendables.
Hope this helps,
---Scott.
Re: ok.. i'm cheap... sand disk questions... *LINK*
I just purchased more discs from Vince in the 3" size. I use a standard Dewalt electric drill. I might try the angled drill some day but this has worked so well and it's less expensive than the better angle drills.
Try one of his starter kits. They are excellent.
http://www.vinceswoodnwonders.com/Sanding_Starter_Kits.htm
Ditto Vince's for Quality & Price
Jennifer@Indy.USA
Joe Fleming
Joe Fleming
Here is my cheap inertial sander: I bought four used roller blade wheels from a lock skate shop ($2/wheel). I bought a tube of bearings - 8 pack ($10/tube). I bought four of the 1/4" bearing inserts for skate wheels. ($1/insert). I stick the sanding mandrel into the assembled skate wheel and, while holding the wheel, press the mandrel against the revolving piece. Total cost of each sander $5.50ish. You and easily swap out mandrel sizes.
I find it amazing to myself that I spent about $5,000 on a lathe, but still scrimp on a $25 tool. Go figure.
BTW - I recently bought the Vicmarc vacuum sander that Craft Supplies had in the clearance section this spring. It works ok, but I'm not thrilled with it yet. I also bought a used sander like the Skilton that Packard has, but I don't think it is a Skilton. Berger maybe?? Finally, I bought some bronze bearings from a local hardware store. Drilled a 45 degree hole through the end of a broom handle and glued the bearing in place. I stick the 2" mandrel on the end of that for the inside of vessels. Works pretty well.
Joe Fleming - San Diego
Bill Blasic
Bill Blasic
I have used Steve Worcester's (Turningwood) sanding disks for a number of years now without complaint and the Skilton sanding mandrels he sells are the best that exist.
Bill
avalon
vince rocks... sandpaper is now obsolete... in other words i got a beginners kit in..
Dick Hines
Dick Hines
I have always heard," use sandpaper like some one else is paying for it."
Mark Ebert
After reading all the reports on disks from Vince, I just placed an order for the 2 3/8" starter kit and an assortment of blue sanding disks. I have an el-cheapo angled drill that I bought a few years ago at the Chicago woodturning seminar and I'm looking forward to trying these out. In the past I've been using the strips of sandpaper from Woodcraft, but I'm tired of burned fingers from holding it too long ;-).
