Failure :-(
Failure :-(
Failure :-(
GolfSteve in Calgary
I supervise a number of people at work and just had a cheer-up session with one of the less confident engineers. Basically if you feel confident about what you're doing, you're probably not trying hard enough, so it's normal for everyone to have some uncertainty about themselves....
I was so tense turning this thing cause I didn't want to screw up. I don't turn much; a few knobs a month ago, and no turning for about a year before that.
Step 1 - Things started out hard. Getting this photo was much more difficult than it should be. Need a nice profile shot with the mouth closed. The piece of wood was also an incredibly abrasive piece of wood left over from my work bench. This wood dulls a hand-plane blade in about 10 swipes.
Step 2 - looking good.
Step 3 -went back to finish hollowing out the inside of the bowl, caught the nib at the centre, and BANG. Failure. My elder daughter decorated the failure for me so I didn't feel too bad.
Re: Failure :-(
Keith Tompkins
Re: Failure :-(
keith tompkins
Bummer, Steve. You might try hollowing the next one first, before turning the details on the stem. Your chance of success will be much greater. Cute kid!
Re: Failure :-(
Re: Failure :-(
I made one of these before but don't recall the process I followed.
I roughed out the inside of the bowl first, leaving a nub for the tail stock. I couldn't complete roughing the inside because I hadn't done the outside yet and didn't want to cut too deep.
Then I turned the outside. I did cut the bottom lip a bit too deep and was left with only ~0.6" diameter at that point.
Then I returned to the inside of the bowl. I still had the tailstock in place and was carefully removing waste. I caught something as I approached the nib and bang.
How you would you complete the inside of the bowl when you had not yet done the outside (which has to be a certain profile to match her face)? Maybe I need to make a template for the inside. I know I didn't do that last time, but maybe I got lucky last time.
Thanks Keith.
Re: Failure :-(
Re: Failure NOT!
Carol Reed, Strawberry, AZ
What a wonderful piece of collaborative artwork with your daughter! May you make many more together!
Re: Failure :-(
Steven Antonucci
Turn th bowl first, then turn a plug for the rim
steven antonucci
If you make the bowl, and then a cover/plate/plug for the rim, you can put it in to use the tailstock for support.
Let us see it when you finish!
S
Re: Failure :-(
Re: Bowl First
Steve Criscenzo
I would turn the bowl first, inside and out including sanding.
Use your tailstock, with a spacer if necessary to contact the bottom of the bowl. I have a rubber lab stopper that I use in these applications to keep the point of the live center from marking the bottom of the bowl.
Steve
Re: Failure :-(
Re: Failure :-(
Dave Belser
As many have said, turn the bowl first. If you are worried about making it to deep/thin, just make another template for the bowl portion from the face template you already have.
BTW - Cool project and cute kid!
- Dave
Re: Failure :-(
If at first you don't succeed........
adrien
Re: Failure :-(
Re: Failure NOT!
dick gerard
You are so right Carol! Great collaboration and what a cute little girl.
Re: Failure :-(
Another difference
Thanks for your ideas everyone.
Last time I made one of these I used a chuck to hold the wood. This time I used a faceplate. If I had a catch when using the chuck, the wood would slip in the jaws, perhaps saving me from a catastrophic failure. With the faceplate there is no give.
Re: Failure :-(
Steven Antonucci
That's not right?
steven antonucci
If you had the piece in a chuck, it shouldn't allow the wood to rotate during a catch. If it is doing that, you need some chuck help...
Steve
