Nova 3000 motor pulley removal
Starry S Chan
What is the proper way to remove the step motor pulley on the Nova 3000?
Starry
Starry S Chan
Starry
Re: Nova 3000 motor pulley removal *LINK*
Henry (Raleigh, NC)
Starry: i have that model - and have needed to accomplish the same thing.
Below is a link to a WC post from a few years back...(my thread - and more importantly other's answers)
Henry W
Nova 3000 pulley removal
Starry S Chan
Henry,
Thank you so much for the link. I will try out some of the suggested methods tomorrow.
Starry
D. Hansen
Starry I had the same problem with my 3000. Took the motor off and went to a local motor shop. They pulled it off with a pulley puller . No charge but they are nice people. You need to be careful not to damage the shaft or the pulley will not run true when you replace it. Liquid Wrench and gentle tapping with a block of wood behind the pulley will also work but I suggest you try to find the motor rewinders in your area for assistance.
The usual problem is the set screws raise a burr on the shaft and this makes it hard to get the pulley off. Using a hand drill put the drill bit in the hole and take a very light cut. That should remove the burr. Then put some liquid wrench in there. Let is sit for awhile. Then make a couple of wooden wedges. Gently tape these between the pulley and motor. It should pop loose. a little wiggling will usually get it the rest of the way off.
Starry S Chan
Thank you for your tips.
I stood the motor on its end and put some liquid wrench down the hole on top of the pulley. I let it soak overnight. I managed to pound the pulley out in 15 minutes using a pry bar against the motor mounting plate. It was not as hard as I thought. The motor shaft is really tight on the pulley even without the key in place. BTW, it is hard to image how the motor shaft can be bent by pounding on the end of the pulley shaft. You need a lot of force to make that happen.
Some of you may wonder why I am doing this. I am having a vibration problem which is probably caused by the misalignment of the spindle pulley and the motor pulley. Somehow, the motor pulley got very close to the side of headstock. I did not know how this could happen. I did not pay attention to this and also the proper mounting of the belt. This destroyed the belt. Before I remount a new belt, I pounded the motor pulley inward but the new belt is not running straight. Instead, it is weaving slightly. I also do not know how this can happen. One of my machinist friends is helping me to check out the alignment of the two shafts. The two shafts have to be coplaner and parallel in order for the belt to run straight.
Starry
Galen Vetterick
Micro-v belts are cut from wide belts and maybe it was not cut true along one side. This can give the illusion of a wobble in the belt. Lay the belt out on a flat surface can show this or turn it wrong side out and observe the edges. It is also easy to get the belt one rib over on one pulley. Make sure it butts to the next larger pulley face and should not overhang any to the next smaller pulley.
If you did pry on the pulley more on one point on the rim you may have bent it off the axis of the hub a little. I assume you have not got the belt too tight as both shafts are overhung and you could be loading the bearings too much and or flexing the pulleys.
Just thoughts about your observed belt wobble.
