Gnarly Problem Follow Up - ShapeLock *LINK*
charlie belden
Earlier, I posted a Gnarly Problem I had with a cracks, crevices and voids filled piece of Manazanita. The bottom was almost all "negative space" - with no apparent way way to turn a tenon or recess for gripping the piece in order to hollow out the top.
I'd picked up a 250 grams bag of a product called ShapeLock at a recent Makers Faire. This stuff comes in small BB sized white hard plastic beads, Heated to 150 degrees F it goes transparent and has the consistency of warmed taffy. Down to about 130 degrees it can be molded into shapes - and - into openings. Upon cooling, it returns to its original hard white plastic state - where - according to the paper work that came with it - it can be machined (and turned?).
Said I'd play with the stuff and report back - which is what this message is about. Here's the experiment with ShapeLock - filling some holes in a piece of Manzanita. When cooled completely, you can, if you press hard enough, dent it slightly with your fingernail. But you can do the same with poplar, cherry, walnut, mahogany and many woods we turn. Don't think its hardness when cooled will be an issue.
What may be an issue is the fact that it doesn't adhere to things other than plastics very well. That means it needs a mechanical means of connecting to whatever you stick it to. Not a problem with what I want to use it for - my Gnarly Problem.
Another potential problem is that it softens again when heated - as in - heated by a forstner bit while turning a large hole in it. As you can see in the bottom right image, a hole drilled in it is not clean and crisp
ShapeLock may just be a solution looking for a problem to solve - like my Gnarly Problem.
If you have any questions about this stuff - ask away
More Info About ShapeLock
