Salt Mill question
Ricc havens
due to the corrosiveness of salt should the inside of a salt mill be sealed or finished in anyway? if so, what do you recommend?
Thanks
Ricc Havens
Salt Mill question
Ricc havens
Thanks
Ricc Havens
Re: Salt Mill question
Salt mill or salt shaker?
Yes, salt is corrosive. Salt is also somewhat abrasive. I'd rather be eating wood than finish.
To answer your question - wood is relatively inert (so are most finishes). I usually just leave the wood as is. I do make sure that it is sanded as fine as I can manage though. I usually do my shakers to 220 grit or so. I have taken a couple to 320.
Forget any inside finishing, because .....
JamieDonaldson
...the wood won't rust!
Walt Bennett
Wood won't rust, but any metal will corrode from salt exposure - including stainless steel. I'm hoping your using one of those composite grinders.
Ricc havens
Walt, yes I am using the mills specifically marketed for use in salt mills. I just wasn't sure if the corrosiveness of salt would have any reaction with maple or walnut therefore requiring some sort of sealing inside the mill
Thanks
Ricc
