segmented questions...
avalon
is there a math formula that tells you how thick (front to back) a segment should be in relation to where it is in the piece... Ie.... how thick should bottom segments be compared to center segments, vs top segments... etc
Re: segmented questions...
Not really. It is pretty much a design question.
As an example, say you were making a sort of hollow form where you wanted a substantial "lip". For that you would have a wider (front to back) segment. If you were to have a bowl without a lip, you would have a thinner (front to back) segment.
Typically at the bottom you would have wider (front to back) segments.
The designers of most segmented pieces usually sketch out their designs (or use a computer program). Usually the inside follows the outside so that you have a reasonable wall thickness. I would sketch out your ideas and see what sort of thickness works for you.
I'm with JL. It's totally up to you. I tend to make my rings about the same thickness (inside to outside) but it's not necessary. The top rings will always be thicker because your cutting through them at an angle. The side rings can be quite thin. I make the bottom a little thicker to add weight so the piece sits more solidly.
I have seen some wonderful things done with rings of different thicknesses vertically. not very often, most people use lumber of the same thickness to make the rings but varying the thickness adds another dimension so the glue lines that are visually part of the piece.
Bill Youngblood
You can go to www.woodturnerpro.com and try the program for 30 days without buying it. It does all the math for you and is very user friendly. Good luck.
avalon
actually i can't use it or any software of that type... i'm a mac using os 10.4.. and I cannot upgrade without spending about $2000 on a totally new computer. My computer cannot run 10.5.
If anyone made a program that works with older macs, it would work.. but no one does..
thanks anyways..
Guy Bratt
I sent an email with a jpg file that I couldn't upload. I lay out my vessel with the wall thickness on graph paper. Then I draw in the segments to cover the wall thickness. Use the proper segment height and the segment width is as easy as counting the squares and partial squares. I hope this was a help.
