Uvex Bionic faceshield
Bill Tucker
OK folks, a bit of advice is needed. Just read an interesting article by John Hart about the Uvex Bionic Faceshield. A bit of shopping research yielded two different versions: the S8500 and the S8510. My question is two fold: What is the difference and which version is best for woodturners? Those of you who use this system, please help me out.
Thanks,
bill
Re: Uvex Bionic faceshield
Stuart Johnson
I have the 8510 and sure can't see any difference between the two. It appears they have the same rating.
Jeff Willaford
From what I can tell.... the S8500 has an uncoated shield and the S8510 has an anti-fog coating. Go for the anti-fog. i have one and like it.
Alan Zenreich
Re: Uvex Bionic faceshield *LINK*
Alan Zenreich
According to their spec sheet, the 8510 has the antifog/hardcoat coating
See the attached link
Here's how another Uvex link describes the AF/HC coating:
-- Permanently bonded to lens, Uvextreme�AF is a superior,
dual-action anti-fog coating that maintains maximum visibility
in humid conditions. When the lens is exposed to extreme
moisture or humidity, its hydrophilic �water loving� properties
absorb and release moisture from the lens. If the lens reaches
a point of saturation, the hydrophobic �water repelling�
properties take over, causing the moisture to sheet off the lens.
-- The Uvex Ultra-dura� hardcoat is one of the toughest, siloxanebased
coatings in the world. Ultra-dura is durable and permanently
bonded to the lens. It will not wear off after repeated cleanings and it
offers superior scratch and chemical resistance.
Uvex Bionic Spec Sheet
Chuck Bjorgen
As far as I can tell the 8510 has the anti-fog feature and the 8500 has the plain polycarbonate shield. I bought the 8510 from Amazon based on recent discussions here. The anti-fog feature seems to work fine.
I compared at this link:
http://www.sperian.com/Products/Uvex/Eye_and_Face_Protection/Uvex_Bionic.aspx?site=/americas
Bill Tucker
Thanks everybody - man I love this group - will be ordering the 8510.
bill
Phil Stivers
Phil Stivers
Thanks to all. I've been looking for a better face shield. On the order list :-)
John Hart
Thanks for reading the article, Bill. Most appreciated. Another thing that I, as well as others really like about it, is that it "disappears" when you put it on. It is very easy to forget about because it is so light.
I'd also like to say that I am in no way affiliated with uvex or trying to market their stuff. Just happen to be happy with the faceshield, that I've owned over 5 years.
Just wanted to say thanks.
John
http://www.woodturnersamerica.com
Bart Leetch
Is there enough room that a 3M dual filter mask be worn underneath it?
Bill Tucker
John - Thanks for the article - never would have found 'em without you! ;-)
John Hart
Yep. I don't use a respirator while turning usually, but I tried out my dual filter mask the other day to answer a question by someone else. The nose of the respirator touches the inside of the shield but the shield is down fully and doesn't interfere.
