Thanks Woodcentral! (fixed alignment problem)
Chris Hoehle
Hello all - My 3520B arrived Wednesday afternoon and last night was the first night I really got a chance to give it a good workout. During this time, I checked the alignment of my drive center & live center points and found that they were off by about 1/16" or so. Yikes! The alignment on my little Rikon is better than that. So, I checked the archives here and found several threads on the topic and one theme that kept coming up was to make sure the bed was level both along the length and across the ways at several points.
I was a little skeptical at first since I had leveled it (or so I thought, to at least what I would call close enough) during assembly, but the suggestion kept coming up over and over again, so I just spent about a half hour or so with my car jack and a couple levels getting it that last little bit from "pretty level" to totally level in all directions and I am happy to report that this did indeed fix the problem! So, I just wanted to say "thanks!" to anyone who posted this answer here over the years (can't remember everyone who did, but I think John Lucas was one) and also to report back here in case anyone else is having this problem to try leveling the bed.
Re: Thanks Woodcentral! (fixed alignment problem)
Good deal Chris. Some people find it....
JamieDonaldson
...hard to believe that a solid iron lathe bed can be twisted to any degree, especially a bed casting as massive as a "Mustard Monster!"
I can't take credit
I probably learned it from some other knowledgeable member of this or other boards. There are so many sharp people out there and when you start putting the information together from all these sources you can really start to solve problems. I'm glad to pass on this info. Just with I had a good enough memory to give credit where credit is due.
