Number one cause of flying wood:
steven antonucci
is operator error!
I'm not a Six Sigma expert, but the unlying concept of Six Sigma is to make something 99.999999% repeatable and reliable. If I was to guess why wood came off of the lathe, I'd bet that this was close.
50% of the time, it is caused by a catch, which can be avoided with practice of proper technique. I would bet that 80% of all catches are caused by someone doing something fundamentally incorrect and not just some minor adjustment in form. (i.e. cutting uphill, against the grain with the flute open)
30% of the time, it is caused by having a poor mounting technique. Improperly shaped tenons (too deep to seat in the chuck, too large for the jaws to grip, not square or flush) will cause the other 20% of catches to send wood flying.
10% of the time, it is procedural. Checking speed, making sure that the blank clears the tool rest, or that everything is locked down. We can all get in a hurry sometimes, but you need to develop a protocol and follow it every time (e.g. I poured bar lube oil in my chainsaw gas tank the other night because I didn't close it immediately like I always do after putting in the gas.)
10% of the time, it is the wood failing. I'd bet that half of the wood that failed should not have been mounted on the lathe BY THAT TURNER. As Clint Eastwood said, "A man's got to know his limitations". Every so often, the wood itself will fail for no apparent reason, but that is rare. I have had tenons shear off of bowls, or hidden cracks in vessels, but I think that I am usually responsible for those things failing anyway. A lighter cut... a sharper tool, slower speed.
So if you want to eliminate flying wood, your biggest source of error is yourself. Develop your skills and working methods to the point where wood only comes off the lathe 0.000001% of the time, or at least strive to move it one more 9 to the right.
S
