NEON light in a future piece?
charliel belden
Saw this at last weekends Makers Faire and, at $10, had to have one!
What it is is a battery pack for two AA batteries, a push button to turn in on and off, a slider switch to make either glow continuously or blin on and off, some shrink tubing to connect the battery pack to the "neon" part which is 3 feet of 1.2mm diameter flexible tubing. It's from coolneon and the have a website (you add the .com) that gives the details on this and other flexible neon tubing they carry.
The specs say you can bend it 180 degrees with an ID radius of 1/8" but based on my experience that would probably need a VERY warm day to do it.
The piece in the example photos is a hollow form failure that I'm working on making a support device for the Stealth Top I posted a month ago. Ignore the piece and focus on the lighting effect.
Comments, suggestions and questions welcomed
