Tracy owen
Tracy owen
Tracy owen
James Pittman
Has anyone tried Tracy Owen round fine finishing tools and how did you like them,and are they better than flat scrapers. Thanks Jim
Re: Tracy owen
Ken Vaughan
Not Tracy Owen but Doug Thompson
Ken Vaughan
Looked at the Tracy Owens tools - and observed they are made on a 1/2 round cross section - and went with the Doug Thompson Fluteless gouge as perhaps better steel, and a bit longer (match for the Tracy Owens round nose in 5/8 diameter) and got the thompson interchangable handle.
The round nose tool takes nice finish cuts and does not catch easily.
It is very similar in section to a tool called the "spindle master" -- but sharpens by grinding the bevel. Also similar at the end to a "skewchigouge".
Have only looked at the angle grind versions, and noted that I can regrind the thompson fluteless gouge if I want to try that configuration.
Re: Tracy owen
Steven Antonucci
Made one (full round) works fine...
steven antonucci
Marginally useful in a transition area like a small box because it rolls easily. The key is how neatly you can pull a burr. I use a green diamond hone and I take a small burr.
As a "skewchigouge" it is almost worthless compared to a skew or a gouge.
S
