Survey - What's your favorite finish for bowls?
Brian McKearney
My favorite finish for bowls for many years has been General Salad Bowl Finish.
What's your favorite?
Brian
Brian McKearney
Brian
Re: Survey - What's your favorite finish for bowls
Jorge Casta�eda
Brian,
If the wood is sound and closed grained I use walnut oil, if it is ring porous I use sanding sealer and then lacquer. The varnishes are hard to repair if damaged and their smell lingers.
Both the oil and the lacquer are easily maintained.
Walt Bennett
Tung oil. I use Waterlox and natural tung mixed about 50/50. It's waterproof, durable and easy to repair.
Mineral oil and a little beeswax
steven antonucci
Functional bowls? Tried and True Wood Finishes *LINK*
Greg Haugen
For Functional bowls I like Tried and True's Danish Oil. It's a polymerized linseed oil that has no thinners or driers. It also doesn't have "nut" anywhere on it's label so it doesn't throw up red flags for some customers. Tried and True also has a finish they call "Wood Finish" which is a heavily polymerized linseed oil mixed with beeswax for a little more of a sheen. It is available at Woodcraft. A quart lasts a long time since you apply such thin coats.
For Artistic bowls, completely depends on the level of desired sheen, what the wood is, etc., etc.
Tried and True at Woodcraft
John Veerkamp
I use Mahoney's Walnut oil followed by microcrystaline wax.
Steve Kubien
Mahoney's Walnut Oil for anything functional. For artsy-type pieces, anything goes dpeneding on the wood and what I want to achieve. Could be lacquer, tung-oil, danish oil...
robo hippy
For all utility bowls, Mahoney's walnut oil. I did use mineral oil for a while, but it dried up quickly. I used to use bees wax as well, but it really doesn't do much. I do really soak the bowls in walnut oil. Nothing solvent based on my bowls. For fancy pieces, I like the floor finishes. They build up quickly, and are very durable.
robo hippy
Lynn Taylor
When I ordered Mahoney's walnut oil from Craft Supplies, there was a small slip of paper that recommended sealing the wood before applying the oil. This speeds things up a lot in that I don't have to wait for the oil that soaks into the bare wood to dry. My intuition tells me to use the oil on bare wood and be patient. Comments?
Carole Valentine
Waterlox Original. Excellent on both utility and decorative pieces. My salad bowl gets used every day, sometimes twice a day and then washed out with warm water and dish soap. Has never stained, even with Pomegranate Balsamic vinegar, and water still beads up on it.
Jorge Casta�eda
Lynn,
I use walnut oil from the health food store, as said in my post above I use walnut oil in close grained woods, apply a light even coat inside and out and let it be 15 min, then with same rag, spin it at 50 rpm and wipe excess if any, most likely there never is excess unless you did use lots of oil, inspect for "thirty" patches and apply a little more there. Next day apply more if needed, also spinning after applying.
If the wood is porous, I use sanding sealer, generously, let it dry a day or so, sand and reapply until the pores are filled, sand again and spray lacquer, I use clear Krylon.
The finer grit you sand to makes a difference, a bowl sanded with 80 grit drinks lots of oil, one sanded to 200 drinks little, sanded to 400 gives you a shinny finish with very little oil.
The lacquer improves to the finer you sand.
After use now and then apply more oil or spray a little lacquer.
I have sold hundreds of bowls and have not had complaints so far.
Greg Haugen
Lynn,
Personally, I agree with your intuition. Put the oil on bare wood and be patient. Also as Jorge said, buffing the bowl (spinning) will aid in the drying process since the heat that is built up will help it dry. I've also heated a small amount (Tried and True or Mahoney's when I used it) in a baby food jar before applying when I wanted it to set a little faster. I've also placed oiled bowls back into my freezer kiln (when there's nothing else in it) overnight to get some added heat on to the bowl.
Tried and True's Oil is applied thin and rubbed in. I let it sit over night and then do another coat the next day. The following day, it's ship-able.
Bush Oil.
Don Orr
Russ no-finish finish
Richard Allen
Russ was a fan of no finish for bowls that would be used. He had lots of good reasons for the no-finish finish.
Personally I like a finish but you should read what Russ has written on the topic.
jim miles - Charlotte
I like Minwax- water based poly- floor finish- 3 coats
Totally agree with Carol...
mjonesrdg
For the last couple of years, I have been making my own "Waterlox" as per Russ Fairfield's formula (and I think about him every time I do) but, for truly perfect and reliable results everytime (which my own blends often lacked) I choose the Waterlox Original. For all open grained wood, I seal with Deft sanding sealer, as many coats as required to completely fill the pores, then finish up with a couple (or more) coats of the Waterlox.
After a couple of awful experiences with Mahoney's Walnut Oil, I would never recommend putting that (or any other non-drying oil) on anything that would leave my shop. A lady customer put a loaf of fresh baked, hot-out-of-the-oven bread into her special wood bowl and covered it with toweling for some special dinner guests. The walnut oil sweat sticky beads on the inside of the bowl and fouled her home baked loaf! She was horrified and terribly embarrassed in front of her special guests. She' had that bowl for about 8 months!
I learned from that experience about a thing wood finishers call "bleed-back".
Brad Vietje
I use Tried & True Original most often. It's so non-toxic you could eat it right out of the can. I've never tried Bush Oil or Waterlox, so I'm glad to read the positive reviews of these.
Have also used Craft Supplies Urethane Oil, and like the results, but not the yellowing of light colored woods.
Safe spinning,
Brad Vietje
Newbury, VT
Dale Jablonski
" The good stuff"
