The only time I get shavings like this while hollowing is if I use a Hunter cuttter in my Jamieson rig, never with a handheld tools or HHS tips in in my rig. What gives? Is it a matter of cutter height or is your skill vs my lack thereof?
That's good Michael. The tips have a fresh burr. The piece is oriented side grain, but the cut direction is not too important inside a piece like this, and I don't worry about it much. This is pretty typical and basically what you should get with decent wood.
John, the air is for after I have used the wire hook to get the bulk out. I blow out every spec so I can get a good clean finish cut without the shavings interfering.
I did not mean to imply I don't stop to clean the shavings out-you should never fight against the shavings.
Hey, Steve, would you be willing to post a picture of a finished one? I'd like to see what your design looks like. Almost dry enough out here to fire up my forge.
