Grain orientation
Grain orientation
Grain orientation
Jorge Casta�eda
Yesterday I turned a walnut blank bought last year that got buried under other blanks I made from a blown down tree in our land.
My usual routine, just was not happening, had to try this and that to find the sweet spot, and as result the shaving ended in a new place.
The wood is very wet, and smells sour, but I was getting "whisper thin" shavings as you can see...
The reason is that the grain in this bowl is a 90 degrees from the usual
I never turned a bowl before with the grain in this orientation and wonder how it is going to move when drying, that was a weed tree, it grew so fast the some of the annual growth rings are over 1"
As I never turned green walnut before,I ask, is it well behaved or crack prone?
Thanks
Jorge
Re: Grain orientation
Greg Haugen
Jorge,
It's looking great so far.
I think walnut is great, "behaves very well". It's one of my favorites to turn green since you can get such a beautiful array of colors and tones in it as well as a nice distinction between the sapwood and heart wood.
Scott Hurley in N VA
I've had some issues with cracking after roughing out a bowl, but mostly it's a beautiful wood.
Scott
Steven Antonucci
Go get the lemon juice!
steven antonucci
Green walnut turns my hands black and the lemon juice not only removes it, but also shows you where all of the little nicks on your hands are!
I would bag it and seal it, but I've had pretty good luck with walnut.
S
robo hippy
Walnut tends to be pretty stable when drying, and not prone to cracking. The finished bowl will have a walnut scent to it for a while, and some people love it, and it drives others crazy. The scent does fade. If you serve hot wet foods in it, it will contribute to the flavor.
Jorge, have you ever moved the headstock down to the end and turned like it is a bowl lathe? Back saver.
robo hippy
Jorge Casta�eda
Robo,
Yes, as a matter of fact right now it is like that, a 21'' ash piece, look the first picture under the lathe, it is there, the trouble is space, while standing there, I am right next to a post, and the floor drops a few inches behind my feet. so I only go there when I must.
Hope to be able to finally build myself a real shop this year, small as it may be.
Philip Duffy
Hi Jorge, I recently turned 4 bowls of walnut from a green log. I did the usual 1in dia, sealed and put in double grocery bags. All 4 cracked! I did not boil them as is my usual routine due to a time factor. Wish I had. Phil
