I have turned quite a number of boxes in bocote but I cannot say that I have had great success with this timber as it seems I almost always get defective sticks to turn. Most often the wood has wind checks or some other internal cracking that makes certain box forms difficult to complete. This stick of bocote was the first that I have had that was sound enough to turn this box form into a piece which I was proud enough to show.
The box is 2 1/4" tall and 3" in diameter and considering the gnarly twisted grain it contains the grain alignment is nearly perfect all the way around.
Great box. I have a love hate relationship with Bacote. The stuff I get only turns with dust instead of shavings and it's nasty and gets everywhere. The finished product always makes me love it but I hate working it.
Toney, oh how I wish it was so....You only get to see the boxes that I think are worthy of posting. It is sort of like the old adage about having to kiss a lot of frogs....Well you have to turn a lot of boxes.
Don, thank you sir. How are you and Laura doing? I hope all is well with you.
Reed, I will try to get some photos of the inside. The problem is when I try to do this I lose all my detail as it goes into shadow. The inside of the box is shaped very closely to the outside of the box. In general the walls are 1/8+" thick. The bottom is a little thicker because I have learned to not let the end grain get too thin or it breaks easily if dropped. The top shoulder is also a little thicker so that you can remove the lid if it tightens up without tearing the box apart.
Thanks, I am trying to figure out how to fit the lid as in tenon on the lid and recess in the box, or just a tenon on the lid and straight side/lip on the box, or recess in the lid and tenon on the bottom.
I have one of Mike's boxes in curly mesquite. I was the lucky bidder on it at the 2009 NC Woodturners Symposium. I look at it almost every day and use it as my inspiration to improve on my boxes.
to make this box. Mike's approach is probably what I would choose too. He has a tenon on the bottom half which fits inside the lid. You could eliminate the tenon on the bottom half and have a tenon on the lid which fits down inside the bottom. I call this a box with an inset lid.
All good box makers use the principle: Make the female part first. Then, fit the male part.
This is because it is easier to adjust a tenon than it is to adjust the opening in a receptacle.
For Mike's box make the inside of the lid first, keeping the tenon on the top, then make the bottom. Before you reduce the tenon on the bottom, but the lid can be put on securely, finish shaping the lid on the top. Remove the lid and adjust the fit. Reverse the bottom on a jam chuck and clean it up.
To make the other box, make the bottom first with a small flat where the lid may sit. Then make the top, by fitting the tenon first (it may be snug or it may be loose), you then make a collet to secure the tenon. Reverse the top with the tenon in the collet and shape the top. Reverse the bottom on a jam chuck and clean it up.
Thanks. I have made a number of boxes (no where near my number of bowls), and for friction fit boxes, usually I make the tenon on the lid. I will try another couple tomorrow. I got 200 maple base ball bat blanks from Gone Batty (can't remember the guys name), and I can't turn them all into rolling pins.
