McNaughton Tips
McNaughton Tips
McNaughton Tips
Richard Jones
So, being as I was a good boy lately, I treated myself to a KM center saver system. I have been reading on tips, etc., and was wondering if experienced users have any ideas as far as a depth gauge goes. I have something in my mind, just curious about other ideas.
Any tips appreciated, not just for depth.............
Thanks,
Rich (looking forward to not wasting as much wood!!) in VA
>>>> Pucker factor is the mother of invention............>>>>>
Re: McNaughton Tips
Re: McNaughton Tips
Carole Valentine
Rich,
Where are you located in VA? Probably not anywhere near the Eastern Shore.
I have the McNaughton system and love it. They make a laser guide for the system as an optional accessory. It attaches to a bracket on the handle.
Re: McNaughton Tips
Re: McNaughton Tips depth
D. Hansen
A simple way to tell the depth is also the cheeeepest. If you look at the assembled soring too you'll see the tip of the coring tool is directly in line with the center line of the handle. I took a piece of aluminum (1/8"x1/4") and bent it 90 degrees. one leg is the length of the cutting tip out from the handle, the other is the diameter of the swing of my lathe plus about 2". When you hold the flat of the device against the face of the handle where the cutting tip comes out of the handle the tip of the device will be over the cutting tip which is in the wood. Just stop the turning hold the device against the handle and tool and you will see where the tool is inside the bowl. Simple and did I say cheeeep. I also have the laser but it is so heavy I rarely ever use it.
Re: McNaughton Tips
Re: McNaughton Tips
Richard Jones
C,
Southside, near Farmville.
I'll keep you posted on my progress, thanks!
Rich
Re: McNaughton Tips
Richard Jones
D,
That's about what I had in mind, and I got nothing against cheap, as long as it works!!
Thanks.
Rich
Re: McNaughton Tips
Re: McNaughton Tips
robo hippy
I have the laser pointer on mine, and have had it there for a couple of years, basically since it came out. Never noticed the weight issue. I did have the bracket welded to the handle because I didn't like having to remount it every time I changed blades. I don't often use it now. Randy Privett of Monster tools also makes a laser that is adaptable to the McNaughton. I haven't tried that one out. I do use the coring tools in the handle also, so the laser pointer comes in handy there as well. What the laser pointer does is let you know where you are all the way so you don't have to stop and check. If you are off course, and need to correct, simple to see and fix before you make a lamp shade, or end up with a bottom that is 2 inches thick.
robo hippy
Re: McNaughton Tips
Re: McNaughton Tips
woodspinner- harry robinette
I made a laser system for mine,I love it and use it all the time it's basically the same as K McN,system and it works great.
Re: McNaughton Tips
Re: McNaughton Tips
Richard Jones
Care to share some details/pics of your rig?
Thanks.
Rich
