No end to how I can screw up
Stuart Johnson
I was turning a pretty little vase from some Ambrosia Maple my trading buddy Steve sent me. For a change I was concentrating on trying to do each step rather than banging into it, letting chips fly and hoping for the best. The outside was turned in one of the most pleasing shapes I've made and sanded to 400. The center drilled and using my Monster rig with laser the top third turned to about 1/8". Well the very top was thicker, I haven't gotten the top corner part down yet. At this point I should have changed to the semi curved tool but as best I can tell started to use the side of the tip. This left a nice laser dot that was not elongated as I proceeded to cut to a -1/64 wall thickness.
New step to add to the check list: Double check the laser dot and what part of the tool cutting tip is in use.
