Further eccentricities.
Leo Cuellar
Leo Cuellar
Has anyone else tried playing around with a tapered glue block? Gives you some of the motion of the Escoulen chuck without all the expense. Lots of variations to try with this. Different tapers, reorienting the piece multiple times on the block face.
Shaped the bottom first on this one then added the taper to do the top. It is just over 5 & 1/2". First stab at this, so the shape is a little uninspired, just trying to get a feel for the process. Kept the speed down under 1000rpm as this was my first time using hot melt glue on the lathe. Was very solid, with no vibration at this size.
Re: Further eccentricities.
Don Leydens
Don Leydens
I haven't tried this method, but it looks very interesting, Leo. Please post any more photos of this kind of turning. Heck, might even try one myself. Thanks.
I make off center pendants by using a glue block that I can mount at different angles in a chuck. It works a lot like the Escoulen because you can rotate it as well as tilt it. I thought I had posted an article somewhere after I wrote the article for Woodturning but I could not find it. I'll keep looking.
Leo Cuellar
Here's a second try, Don.
Leo Cuellar
This started out as a 7&1/2" square. I wanted to try something with wings, but I guess that is gonna take more than a few tries to figure out. I had to use my counter-weighted 2 jaw chuck as this size produced some vibration when I first spun it up.
I have to figure out a way to keep thing aligned a little better using glue blocks. Perhaps drilling the center & using a dowel to line things up. Kept the speed under 800rpm. I'm really beginning to like the hot melt glue over other adhesives for getting stuff back on the lathe quickly.
Don Leydens
Very cool!
Don Leydens
I love the swirl pattern, Leo. That whole idea is coming along great. You even attacked the bottom! Can't wait to see where this will take you. Thanks for posting the shot.
Don L.
