I have turned on one in the past, and as a bowl lathe or for vessels, I would say go for it if the price was right. My only drawback would be if it was the only lathe I owned, I think it's got some length issues.
It is very nice to be able to stand in front of the bowl while cutting it, and that's the Vega's best feature.
I have turned on a couple of them and would love to own one. But I do mostly bowls and hollowforms and very little spindle work. It has a very short lenght, like maybe 14" or so, but it is an excellent bowl lathe.
I have and use a Vega 2600 and love it. It is a bowl lathe thats 17" between center and is actually 13 1/4 center to bed. I've had my Vega for about 7 years and do allot of large bowls, I put a electric hoist above mine to get the bowl blanks on the lathe I figure a blank 24 x 10 weighs about 110 to 130 pounds. I also have a 18" General bed lathe which I use allot too. I do believe you will be very happy with the Vega as a bowl lathe. There are a couple things that if you buy it you can contact me and I'll help you out with it.
One thing you'll want to get for it is a coring system,I use a McNaughton system and love it.
Like I said you can contact me at woodspinner@neo.rr.com any time. And good luck.
Sort of a where's Waldo. What is unsafe and what is good safety depicted in this video?
This isn't about the guy turning wood as much as it is a discussion about safety. I have no doubt that many many safety issues could be identified if a video of me turning wood was viewed.
What do I see unsafe in this video?
A face shield should be worn. Not likely life threatening but can certainly save some hospital time.
What about how the woodturner positions his body while turning the hunk of wood? He could have switched hands to put his body out of the line of fire. Death is a possibility.
The woodturner stood directly in the line of fire as he started up the lathe. Death is a possibility.
The woodturner didn't bother to sweep the floor before he started turning. A clean floor provides better footing. Likely not life threatening
The woodturner is wearing a glove on his tool rest hand. That glove could get caught between the tool rest and the spinning hunk of wood ... Likely not life threatening
No tailstock in use. The use of a tailstock vastly improves the security of the workpiece mounted on the lathe. Death a possibility
The woodturner didn't anchor the handle of the tool to his body and his body didn't flow with the cut. Likely not life threatening
No dust control, though we tend not to need dust control when roughing green wood. Long term health effects.
I would have liked to seen a fire extinguisher mounted on the wall by the door on the way out of the turning "studio". Maybe he had one on the other side of the opening.
What safe practices are shown in this video?
A good sized face plate with numerous screws is a very secure way to mount a work piece.
The lathe was set on the low speed pulley.
The woodturner wore safety glasses (they look like safety glasses).
There was a person watching who look to be able to render assistance if something bad happened.
The tool appeared to be sharp.
The wood appeared to be sound, no obvious checks or voids.
The woodturner wore suitable shoes. There are some turners who wear sandles or even go barefoot.
The woodturner wore a short sleeve shirt. Better would have been a tight fitting smock but at least the shirt was not likely to get caught in the spinning blank.
The workpiece was turning at a slow speed though that is one of the failings of that lathe. Two speed ranges, very slow to slow and slow to fast (but the slow on the fast speed range has no power).
There looked to be clear (except for the mess of shavings) escape routes.
Loads of light and it is very difficult to beat natural lighting.
Great ventilation being open to the world like it was. Being open like that can open the turner to surprise from unexpected visitors like animals or bugs.
The side of the lathe opposite the tool rest was clear and nothing mounted on that surface which might encourage him to reach across the lathe.
A mostly monochrome surface to make his form stand out. He could paint that wall white or black for slightly better contrast.
The woodturner looked to be very comfortable at the lathe. It looked like he was well within his comfort zone.
