delta 45-450 lathe spindle
Rob Cohen
I managed to slightly bend the outboard end of my delta 45-450 lathe spindle when turning a fairly large bowl blank outboard. Inboard end is still fine and the lathe still operates fine.
I was looking for a replacement spindle but....read on
I actually have an original manual for the lathe.
It says if you ever need to replace the spindle, you need to send Delta the entire headstock as the morse taper final machining needs to be done after the spindle is installed
Any advice? Should I be looking for an entire headstock?
I have the headstock pulled and the bearings are just fine. I must say that I'm amazed how easily it bent
Time to give it up???
Rob C
