Delta 46-745 Opinion *LINK*
Jon M
Saw this Lathe on CraigsList and I was wondering how well liked it was. I've just started shopping around for a full size lathe.
Delta 46-745 Lathe
Jon M
Delta 46-745 Lathe
Re: Delta 46-745 Opinion
This is a reasonable lathe. Much better than my old 46-715.
Caveat - there are many who prefer cast iron beds rather than steel beds. I'm one of them. I also prefer a heavier lathe.
Would you be happy with it - probably. It has three speed ranges and a 1 1/2 hp motor. It has a reasonable bed length and a reasonable throw. If you aren't going to be turning lots of big bowls, it should be an excellent lathe.
Jump on it.
It was introduced shortly after Powermatic came out with the 3520 and then a few other manufacturers followed suit. Delta just didn't keep up, or the lathe sales simply weren't that important. I don't know but the lathe sort of quietly dissappeared. It wasn't a bad lathe and at that price if everything is working correctly it's pretty good. If there is anything wrong I would stay clear because parts may be hard to come buy.
Fred Bearman
As to parts for this lathe, there was a post on rec.crafts.woodworking in 2007 about this lathe, and the poster was told by Delta that they no longer had any parts for this lathe. The particular part he was looking for was the variable speed controller, no longer available, but no other parts specific to this lathe are available either.
That said, this is used, no way to fix it - I wouldn't pay more than $600, but that's just me, I guess.
Ditto on the $600 or less.
Rick in Colgate, Wi
I've had mine for 10 years now, it is American made, newer versions were not. Couple features I like are the VFD and moveable headstock. Only problem I've had was the lock lever for the tool rest post broke but I made a new one by bending a long bolt. The legs can be filled with sand for added weight and a shelf can be added below the bed for storage or whatever, in my case sand bags.
You can replace the Variable Frequency Drive with an aftermarket one but you need someone knowledgeable enough to help you by one that matches your motor and enough electronics skill to install it and maybe reprogram a few parameters. I would think any good motor repair shop could do that.
Fred Bearman
I would think that you could find a variable drive controller, but the post that I referred to tried that, and what was marked as L1 on one didn't mate with L1 on the other, etc., and it didn't work. My knowledge level would be similar to this. And I have not been impressed by motor shops around here.
I have several takes on this post:
1) I don't know his level of experience with turning or with tools, and so I will assume (probably wrongly) that he is a beginner. As such, I think that we would all want him to have an absolutely great experience, so that he also gets sucked in with the rest of us. At this level, does he have the knowledge and experience to evaluate this tool, as to everything being fully and properly functional. Seeking out a local turning club could possibly be of assistance to him, and would be a good move anyway.
2) It concerns me that, presumably, this lathe has been just sitting for a prolonged period of time. Two or 3 hours of use in a lathe that hasn't even been manufactured for quite some time would seem to indicate sitting in a corner gathering dust.
3) At the $1200 price range that the seller is asking, you are in the wheelhouse of several lathes brand new, that would seem to be of reasonable quality, among them the Jet 1442 and the Nova 1624. I'm sure that there are others. These would be new, presumably have some sort of dealer support and a warranty, and have a higher chance of resale if this turns out to be not the area of woodworking that the poster was hoping to be involved in.
I am looking at this from my point of view, and I'm certain that others have other points as they see them. For me, I am not overly skilled at fixing things when they are broke, and I'm certain that is greatly affecting my take here. I also want the very best for my dollars - and there are some things about this Delta that are very appealing, particularly the basic very solid construction. Anyway, that's my nickel (two cents went by on the pump with the first paragraph!). Take it for what it's worth.
Fred Bearman
Port Huron, Michigan
Paul Simon
I am an new learning turner. I bought a used 46-475 from a woodworking club for under 500. I like mine, it is variable speed, reversible, 3 speed ranges, knockdown for moving, and heavy enough for stability.
I am learning through the WC, AAT, and the local woodturning club enhancement classes. Paul
Jon M
Thanks for all of the replies. I think I'll pass on this one & look for a more current branded model at the same or lower price point.
While I have been making furniture pieces for a long time, I was looking to turning to expand my capabilities. When I first looked at prices for good lathes I had sticker shock.
No rush anyway. Frankly my shop needs a little clean-out before I could fit it in.
