Risk & speed go hand in hand
pete labelle
I often bring new woodworkers into my shop to build projects. Many are teens. Most have never operated tools or equipment, so safety guidelines are talked about before a machine is turned on, and as situations present themselves.
One example I do to show how speed and risk go hand-in-hand is this:
1) Pick up a dowel & ask how long it would take to saw off your arm. The student will often say it can't be done, BUT, with several days work, you can cut off your arm with a dowel thru pure friction.
2) Pick up a hand saw and ask how long it would take to cut off your arm. Reply is around a minute.
3) Turn on the table saw and ask how long it would take to cut off your arm. The reply comes back at a couple seconds.
Thus, the faster that a tool or machine has the ability to do an operation on a piece of wood, the greater the risk, and faster the time that an accident can happen. This is why you learn on hand tools, then migrate up to power tools, ONLY to speed up your wood processing operation.
This seems to click with the "students" in my home shop.
Major accidents in wood shops would greatly diminish if we would become patient, and we all went back to using hand tools. Probably won't happen in my shop though.
Play safe boys!
My 3 cents (adjusted for inflation).
Pete
