200+ woodworking book reviews
Die Grinder and Ball Cutter Test *LINK*
Stuart Johnson
In last night's chat we talked about using a die grinder and ball cutter in the same manner as the Decorating Elf Tool. I have a HF 1/4 pneumatic die grinder that I have used in passive mode for sanding plus some old ball cutters. So I gave it a quick try this morning. I don't think at this point I've given it a fair test.
1. The ball grinders are old and not real sharp.
2. All I had on hand for a quick test was a Poplar glue block.
I cut a couple coves and like Earl suggested last night I started off slow to allow the grinder to come up to speed. This was harder than I thought because I was using both hands to hold the grinder which left me one short for trying to increase the speed. I went ahead and started at around 800 RPM and had no problem with the grinder coming up to speed. By the way this was passive not powered.
The grinder does not make a good tool handle so I attempted to use the cutter shaft on the tool rest. This worked but it quickly wore a nick in the Robust rest :( .
I did start to get a pattern but the soft Poplar didn't didn't give it a chance to develop. I'll give it a second test later on with either some Ash or Mesquite. The end result is I think it will work with some practice, decent cutters and a hardwood. My main concern is how to hold the grinder so the tool rest isn't damaged.
Decorating Elf Tool
Re: Die Grinder and Ball Cutter Test *LINK*
Jeff Willaford
Thanks for the update Stuart. Sorry about the tool rest. :(
I had completely forgotten about the Decorating Elf. I meant to try it using my Foredom handpiece. I'll try to remember and try it out later this week,
Lan Brady
Stuart,
Great follow up.
I plan to still make my own Elf, but I may pick up a die grinder at hf to play with as well.
Thanks again, Lan
Stuart Johnson
John, there was some talk about the amount of pressure needed and possible damage to the Foredom handpiece.
Stuart Johnson
Lan, how about some step by step pictures when you make yours?
Lan Brady
I dont presently own a camera, but I will see what I can do.
Lan
Re: Die Grinder Test2
Stuart Johnson
A little better results using some scrap Mesquite. I'm still using the dull cutter and have found a better way to hold the grinder. The guts of the grinder is about 1-1/4 x 2-1/4 inches with a 2 inch rotating shaft. My next step is to turn a handle to hold the rotating part of the grinder. The circumference won't be much less but will be much easier to hold. I also need to purchase a new cutter before I try using the tool on anything but scrap.
On my screen you need to scroll down a bit to see the die grinder parts.
Dick Wilson
Stuart, I didn't get a very good grasp of what you were talking about last night. After watching the video I understand :D Not being a Rube Goldberg it looks like a tool that can be made - a inside bearing or two in which the cutter slides inside the bearing, press fit the bearing(s) into a handle and off you go. Keep us posted. Thanks. Dick
Ken Vaughan
Ken Vaughan
I have used a Foredom handpiece (8D as I remember the designation), and it works as an elf style tool -- except that the coiled spring tail on that handpiece flops around and is a bit awkward.
Have used the elf style tool for both 1/8 and 1/4 shank cutters -- and the 1/4 shank cutters worked a bit less well (using new carbide milling cutter).
Don Leydens
Don Leydens
I gave this a quick shot using a Dremel with a flexible shaft and the motor turned off. It worked OK with gentle and increasing pressure (using carbide bits) on the wood. I still have to try it with the shaft taken off to decrease the drag from the cable and just use the hand-piece. I suspect it will work much smoother. Worth a shot anyway.
