wet sanding
wet sanding
wet sanding
Bob Strand
I'm making some small, segmented urns out of re-claimed maple flooring and black walnut and would like to have some input about wet sanding. I've been using Deft lacquer thinned 50% with thinner and going up to 320 grit with Abranet. I like the Abranet product but being unfamiliar with wet sanding I'm wondering if there may be something better to use. After an overnight dry I'm finishing with an equal mix of tung oil, spar varnish and turps applied with 0000 steel wool. Not totally disappointed with the results but perhaps there's something better or easier.
Thanks.
Re: wet sanding
Re: wet sanding
steve worcester
Abranet is an "acceptable" product for wet sanding between coats. After all the coats, IF you are going to buff, Abralon would be a better choice after (since Abranet only goes to 1000) as it is 320, 500, 1000, 2000, 4000 to get to a buffing stage.
There is also Trizac from 3M, about the same price I think, and about the same grits
