I would like to get a high gloss finish on some turnings. Since I'm returning to turning, I don't think I'm up to date on what's good. I've been using friction polishes like HUT with good results, but I want a finish that looks like glass. Maybe I'm not using the HUT product correctly.
...Crystal Glaze, in rattle cans from WallyWorld unless someone can tell of another source. I "sand" with 3M Trizact 1000~3000 polishing pads, then use a "French polish" technigue with cotton pads and Nu Finish car polish, tricks I learned from Gary Sanders several years ago.
I suggest spraying lacquer in multiple coats, and doing some sanding, flattening, etc,. between coats if necessary.
I don't have many positive experiences using friction polishes on bigger pieces that are intended to have glossy, glass-like appearances, and have mostly abandoned "friction polishes" for all but a few kinds of pieces (mostly smaller things like bottle stoppers, pens, etc.).
I know there are others on this list that produce pieces with excellent high gloss finishes - Steve Worcester comes to mind.....
Your quest is not that complicated. I'm a hobby turner but a cabinet/furniture builder and finisher by trade. Use any fast building lacquer on your object to lay down several good coats. Wet sand it down to 400-600 grit. Go to your local auto body paint supplier and purchase 3M or Meguiars (sp?) polishing compounds that are in large bottles. Get a cheap polisher/buffer. Mist the object with a little water and apply the first coat of compound and slow speed buff it. You can progress through several levels of compound until the object looks like glass. We use this for small objects all the way to complete kitchens. It is fast and fairly inexpensive.
The concept of getting a glossy finish is simply. Build enough finish to fill the pores and any other small defects in the wood. Level this finish, and then polish the finish.
Now what finish you use gets challenging. Lacquer, shellac, and even polyeurethane are the most used. Apply a coat, and then sand it flat. I use 600 grit unless it's really not flat then I go down to 400. Apply another coat and sand. When the sanding leaves a flat satin looking finish your ready for one last coat. Apply this and let it dry to where it can be rubbed out to a gloss. This might take several days to a week for some finishes.
For larger projects I use pumice and rhotenstone. For smaller projects like most turnings I use automotive polishes. White polish followed by swirl remover usually does the job. Some use Micro mesh finishing paper. That's good also.
Your quest is not that complicated. I'm a hobby turner but a cabinet/furniture builder and finisher by trade. Use any fast building lacquer on your object to lay down several good coats. Wet sand it down to 400-600 grit. Go to your local auto body paint supplier and purchase 3M or Meguiars (sp?) polishing compounds that are in large bottles. Get a cheap polisher/buffer. Mist the object with a little water and apply the first coat of compound and slow speed buff it. You can progress through several levels of compound until the object looks like glass. We use this for small objects all the way to complete kitchens. It is fast and fairly inexpensive. We have photos available.
Where have I heard of that technique?? Jamie, I also still use the trizact and also still buff out with the plastic polish. I just completed a few turned acrylic stands for some of my work and the technique finished off with the plastic polish worked like a charm. I usually use various forms of lacquer for the finish on wood with a high shine.
..my cars for years, but never considered that it could be applied to wood finishing. It seems to produce a very hard surface and shine, doesn't show fingerprints easily. I bought a package of gun cleaning patches for polishing pads, nice clean cotton and cheap!
Before I say anymore, the picture is of a turning by Paul Porter.
That being said, would a spray (rattle can) lacquer product such as MinWax be sufficient? Secondly, as far as buffing and sanding that several have described,would that be done prior to removing the turning from the lathe. I'm assuming yes. Not that it couldn't be done otherwise.
Sand on the lathe up to about 320 or 400, then start the finish regime.Off the lathe to make sure you get all areas. Rattle cans can work, but they don't spray as thick so you will need more coats. You can do a coat , sand 320/400 to get it flat and promote adhesion, shoot a coat, sand, etc until you have enough coverage to sand it higher grits and buff with compounds. With a rattle can, it could be 4 could be 8 or more.
Compounds, 3 with 3M, are going to get the scratch pattern to the point you don't see the pattern any more. Usually last coat from a can, maybe 800-1000 grit to flatten and then up to 4000 and start the rubbing compound, Swirl Mark remover then Final glaze. Final glaze doesn't change the look, but definitely the feel of the finish to smoooooooth.
Steve described it well. I also do it off the lathe. You have more control of where you sand so leveling the surface is easier. Remember all you are trying to do is refine the finish. The vessel should already be sanded to at least 400 grit.
If you want to try something faster and almost fool proof try Birchwood Casey true oil. It is a gunstock finish. It is a high build finish so it takes about 5 to 10 coats to get a glass smooth finish. You apply a coat, and then use 4/0 steel wool and remove all of it except what is in the pores of the wood. You will see glossy spots, those are the pores. Apply a new coat each day and before applying another coat steel wood the last one until only the pores are glossy. After 4 to 6 coats you will have a surface that no longer shows the pores. Apply one more and you will have a very glossy surface. Most people will be happy with this last coat but if you want really really smooth and glossy you will have to go one step further.
If you were careful with your early sanding you may have surface that you like. if not you will need to level the finish with 600 grit or higher and apply another coat. Then it's just a matter of polishing this last coat.
The one problem with True-oil is that it darkens the wood quite a bit. It looks fantastic on Walnut (think gun stocks) On lighter woods you may not like it so run a test. You can purchase it at most outdoor stores and sometimes Walmart and Kmart.
I use True Oil on a lot of my small boxes. Once you have the first few coats on and have steel wooled between them, start applying the next coat with 600 or finer wet/dry sand paper. After about coat 5-6 I put a drop on my finger and use the palm of my hand to rub it in. This is not putting much of the finish on, but does spread it evenly. The last coat I put on with a fine cloth and use that cloth to polish to a high shine.
