Thoughts on church torches?
I got my bed extension for my 1642. I'm ready to start work on the church processional torches.
I figured I ask opinions on my ideas.
They will be using oil filled candles with a threaded base (1/2 x 13 tpi). I was figuring on making the poles about 45" or so long. There will be a small "saucer" on top of the pole with a "candle cup" that is purely decorative. I was going to drill out the top of the torch for either a piece of all thread or a portion of a 1/2" bolt.
So I got to thinking. I was figuring on making the pole diameter about 1 1/4". I figured that would be substantial enough to give the acolytes (torch bearers) something to grab. I was thinking about making a tenon on the pole end on which I could mount the "saucer" or "bowl". The tenon would extend through the saucer and I was going to mount the candle cup on the end of the tenon.
The candle cup would have a 1/2" through hole and a partial hole for the tenon. I was thinking about making it so I could just put a bolt through the hole (for the candle). I would then epoxy the bolt in the candle cup and glue the entire thing to the top of the pole. I would probably recess the hole in the candle cup so that the bolt head wouldn't interfere with the gluing of the tenon.
Comments? Other thoughts? Do ya'll think this would work?
TIA
