Source for long tool rests for Jet?
Affordable ones. Source for banjos also.
Re: Source for long tool rests for Jet?
Carole Valentine
How long do you need, JL? I don't think you can get a better tool rest than the Robust Comfort Rest. If you want really long, I would think the quality is going to be important in order to avoid vibration and flex.
Re: Source for long tool rests for Jet? *LINK*
Andy Lincoln,in Dearborn MI
JL,
Don't exactly know if these will work for you but a gentleman over on IAP makes toolrests.I have one for penmaking and I love it.I would bet that he could make something that fufills your need.i have sent his email info to you in a separate email.
About 20-24".
I figure if I got a long tool rest it would be easier to turn legs and also easier to turn the torches.
Nick Tuzzolino
I had custom tool rests made for both of my lathes by Jeff Nicol. Great prices, great workmanship.
www.woodennicol.com.
Katherine Kowalski
The simplest (and least expensive) way is to make your own out of wood:
Get a long bit of hard wood, like oak, and drill mortises for two (or more) tool-post sized tenons, (usually 1" round, but measure to make sure). Glue in two wooden tool posts, then insert into two banjos. Instant long tool rest.
we made ours
Jorge Casta�eda
JL,
many years ago I helped a fellow to rebuild a partially burnt 4 story stairway, he had two banjos, got two 6" lengths of 1" bar and attached a little longer than full length I"x4" white oak with a rounded edge, we put marks on it of where the cuts went, it worked very well, the job was getting the second banjo, he managed to borrow one from somebody.
Dave Peebles Lyons, Ohio
Hi JL,
I do the same as Katherine Kowalski. My choice was maple, but any hardwood will work fine.
I was making Shaper chairs and found the long rest to be a real timesaver. And, they hold up surprisingly well.
Best part... it cost me a little time and some scraps.
Dave
Options
steven antonucci
You can do what KK mentioned.
A buddy of mine did this and put some angle iron over the top to give himself a metal surface to ride on.
I personally went to the scrapyard and bought a 1" steel bar and just tapped a hole in the bottom for my interchangeable tool rest system. My second banjo is a deadman, or you could make it out of scrap woodto bolt to the ways.
Steve
