Re: Chain Balance
Hi John,
I used to file, the I fussed with a Harbor Freight grinder, then a friend's Dremel, until I finally went out and bought a real chain grinder. I bought a Tecomec which is very precise and will grind any chain that I'll ever have use for. I set my chains up with my personal grind angles and I take them off the saw when they barely start to drag. That way all I need do is "kiss" them with the grinder and they're right back to sharp. My friends all bring their chains over to me and they brag about how much smoother and faster they cut. The first job with their chains is to mic all the cutters to find the short one (after the lawnmower shop does them once they're way off), and then set the stops to that measurement. The cutters all come out within the tolerance of my digital mic which runs to 4 decimal places. Grinding the depth stops is equally easy. I get more than 15 sharpenings out of a chain before I pitch it, because I'm taking so little off the cutters each time. Takes me 5 min. to do each side of a 28" chain plus another 10 if I have to grind the depth stops.
The Dremels and files are fine for use in the field, but when I go out cutting, I'll take 3 chains for each saw so I don't need to fuss with sharpening anyway.
