continuing dialog...
GaryG in MD
Thanks Emmett, Jamie, and Brad for your thoughts -- and Dale earlier. You've given me some good ideas.
To be a bit more precise, this is a small piece of a burl cap, about 4" long and 1" "square" with one flat end and the "top" end being the burl points sloped at an angle of about 40 degrees from side to side. My intent is to leave the outside "square", part off about 1/3 for the top section (hopefully without chipping the corners), hollow the bottom section a bit, and put a tenon on the top section to fit into the top of the cavity in the bottom section. If I can figure out how to hold the top section, I'll do a little decorative work on the inside of the tenon -- or at least make it concave.
Clearly, I don't want to damage the burl end with a tail center point. Because of the aspect ratio, I'm a little concerned about putting it on a glue block, but that might work. I obviously can't use a steady of any kind, and I can't bring up a live center point for support. The idea of embedding the burl end in a piece of "insulation" is intriguing. A piece of high-density foam might work to provide the needed support without damaging the points. That and a glue block should be enough to handle it.
OTOH, Dale's idea of making a couple of thin shims still has merit too. It's not off by much, so it might just take a couple pieces of thin metal sheeting to do the job. The problem there is it will never be quite exact and may vibrate, and I don't want to squeeze the chuck down too tight and make compression marks on the two sides of the burl. Trying to center it inside 4 surrounding pieces of thin wooden shims may be the best answer. That way I don't have to worry about compression marks or popping the glue joint, and I wouldn't have to deal with the tail end at all.
So it looks like I have two pretty good methods, thanks to you all.
I'm still open to more thoughts...
Thanks for your contributions guys, Gary
