Stump wood
Mark J. Thill
Has anyone had any experince turning stump wood. There clearing out a lot of the forest area around here and they leave the stumps to rot. Are they like burl wood. Mostly pine, ceder and juniper wood.
Stump wood
Mark J. Thill
Re: Stump wood
John Veerkamp
Stump wood is usually like rest of the tree wood. Cedar and pine are cedar and pine. Occasionally down where the roots come from the main stem there can be some nice figure, but it is not certain. If you don't normally like these species, try a few but don't go hog wild.
Re: Stump wood
I had a maple tree in my yard and a hurricane blew it over. The tree had roots girdling it, probably from have been grow in a pot and then planted without straightening out the roots. I turned several bowls from the root stock. One was the from the very bottom of the log and is about 15" in diameter. The wood looks slightly different from maple and has evidence of roots taking off in a circular pattern. I had two of these and gave one away. I turned them green to finish and they warped a little. Like them a lot. there was another that came from a snail of roots and it was a series of sort of oval "flakes". The person I gave it to bought a glass bowl that fits inside it as if made for it and they use it to serve chips or whatever at parties.
So, there may be some interesting stuff in there. Not sure about the species you have, but you could give it a try. Be aware that I use a power washer to get the dirt off the stump I had and by the end I was wearing most of it. Somehow it transferred the dirt directly to my person. Wear Eye protection and a full body condom. I was very pleased with the bowls, but it was a lot of work. I still have one of them and could post a picture if its important to you.
Re: Stump wood
Dick Coers
Stump wood can have some dramatic grain direction changes, and can be beatutiful. It can also have ROCKS inside. Tons of dirt and those rocks make me stay away from that wood like the plaque. I have a cherry slab on the wall as a reminder. Bandsaws don't like hitting rocks!
Re: Stump wood
woodspinner-harry robinette
Stump wood,Dick's right stone,dirt,nasty but sometimes beautiful. Make sure to pressure wash it at lest 2 times with a day drying time in between,the drying keeps you from saturating the wood very deep.I know there can still be something nasty inside but most of the guck and sand will be cleaned out.
As always just my $.02
