Sawing Log help!
Sawing Log help!
Sawing Log help!
Ricc havens
Just got a small Stihl 211 chainsaw with 16"bar. Yes, I know it's small and I could have gotten a longer bar with a cheaper saw brand but I took the suggestions I have read here in other posts to buy the best you can afford.
Now need a good way to hold the log for cutting into bowl blanks. Anyone have any ideas or pics or plans on what you use?
Thanks
Ricc Havens
Re: Sawing Log help!
Steven Antonucci
What you need...
steven antonucci
There are numerous designs for a chainsaw bench, but it's more a requirements exercise than a design exercise.
Here are my requirements:
1.) Absolutely no metal in the cutting pathway. My bench is some old landscaping timbers that I pulled up and the legs are screwed in at the ends, but all cutting happens in the middle. If I overshoot the bottom of the log, no metal to wreck my chain.
2.) Height should be high enough to cut comfortably without bending over. The corrollary to this is that you have to make sure that it's not so high that you cannot lift a big log on it. Mine is high enough to make the bar about level with my knees slightly bent.
3.) Stability: I cut logs in the right sequence to minimize repositioning and rolling around. Bill Grumbine used to have a tutorial on his website, but the short version is that you make 2 cuts on either side of the pith and two cuts for the bark, but stop short of completeing them. I have an upright on my bench that I can snug a log against to keep it from rolling around, and I use the offcuts as wedges.
Steve
Joe Bradshaw
Joe Bradshaw
Ricc, I made a stand for cutting bowl blanks from 4 x 4's. I cut eight pieces about 24" long. I drilled holes in each end and centered on the width. I made the holes large enough to slide a piece of 1/2" pvc pipe through. I then stacked the 4 x 4's log cabin style. With no metal parts, I didn't have to worry about ruining my chain.
bill Crommett
Another tip. I glued with hot melt glue a couple of pieces of 2 X 2 as sacrificial protectors to keep from destroying the basic bench construction when the saw finished cutting through the blank.
Nothing! :o))
Jorge Casta�eda
Ricc,
I am basically a very lazy guy and don't do anything unless i must. To use a saw bench I have to lift the chunk, and my back and my broken rib scream Nooo!, so I don't and cut right there where it lays, go down 3/4 of the way and then turn the chunk end for end and finish the cut, no bench involved. I made a small platform with 2x6" lumber and sometimes I roll the chunks up there and then make the cut in a slot...
Then I trace the biggest circle with dividers and cut the corners, still on top of the platform and flip the blank and trim the upper corners on the end grain, presto chango!
To the lathe...
Roger
I have a large piece of poplar log 20" in dia.and 2'6" long sitting on end with two V grooves/notches cut like a cross in the end of the piece facing up. I lay a section of log to be cut into blanks in one of the V's and it's very stable while sawing.
Richard Jones
Roger,
I like that idea. Nice and simple.
Thanks for sharing.
Rich
THANKS EVERYONE!!  NM
Ricc havens
