Oland ruffing tool???
Bart Leetch
Anyone heard of the Oland ruffing tool?
Here is a description of how to make one.
http://aroundthewoods.com/oland.shtml
http://www.youtube.com/watch?v=vG_Va-NE0cM
Re: Oland ruffing tool???
It is just an early version of the Easywoodtool but not carbide and a smaller cutter. Or you could look at it as a John Jordan straight hollowing tool. In other words a big heavy duty scraper. You can buy the steel at any good metal supply house. They usually come in 3" lengths. You can shorten them by a couple of methods. notch the corners with file and then break them by putting one end in a vise and hitting the other end with a hammer. Put a rag over it if you do this so it doesn't fly across the room. (or you could just use large pliers) You can notch it with a Dremel witha cutoff wheel and break it, or you can simply cut it in two with the cutoff wheel. Then drill a hole in the end of your steel bar, put the cutter in and either glue it in or use a set screw.
Knud Oland also make probably the first High speed Steel parting tool. It was a High Speed Steel metal cutting parting tool mounted in a bar and had set screws so you could adjust the length it extended. I had one and didn't like it for what it was designed for. It actually worked very well and cuts cleanly. The problems was two fold for me. One is the cutting edge is quite high and if you weren't careful you could get a pretty good catch. Second was you either had to leave it extended all the way which left a fair amount of tool out in the air unsupported, or you had to constantly adjust the length.
My new tool that I am using to part off the rings on my stack laminated bowls is the same tool but it's held in a captured boring bar. so I get the advantages of a clean cutting, non burning tool, without the catches.
Steve Harder
I'm using my Oland style bits in an elbo tool to get the same fine degree of control and cut that John just mentioned. When not held in a capture system of some kind the bits can be a handfull, but captured they do an excellent job of hollowing and exterior cutting.
Also using the elbo to hold captive ring cutter (allen key ground down).
Does take away some of the potential for excitement at the lathe ...
