Goya+Aladin+Drozda = ? *LINK*
charlie belden
Accidently deleted my original post while trying to edit the text. OOPS.
So I'm trying again.
Serendipity Example # 2, 714.
Just to see if I could, I turned a long slender finial - a la Cindy Drozda's - out of oak - just to make it interesting. Oak is interesting to turn - normal sized pieces. A bit more challenging when turning long, thin and delicate - its open pores often leading to nasty catches - on small thin turnings. It's also proned to flexing when a little more pressure than necessary is applied to it.
A sharp tool, plenty of light cuts and a bit of sanding and I had a long sort of delicate finial - that was boring. As noted, oak can be interesting to look at - if there's enough of it. But with this finial - there wasn't enough of it. So I dyed it - with TransTint Aged Maple. While I was at it, I also applied some Black Shoe Dye. I liked the results - and kept the finial - figuring I might come up with a piece to stick under it.
Two weeks later, our turning club's annual Tops Night was coming. So I thought I'd put a small top under my Goya-esque finial experiment. I like doing pieces that move - and tops move. But I didn't want the piece to LOOK like a top - but rather behave like one - and look like something completely different.
So I'm thinking some kind of elixer bottle - with tall delicate cap might do. And an Aladin Magic Elixer bottle - squat bottom and long thin neck - came to mind. Low center of gravity, tall thin neck, symetric about its vertical axis - meets the criteria for a spinning top. To minimize its contact with the surface it'll spin on - a small steel ball bearing - super glued in a depression on the bottom.
That bearing, and the roundish bottom meant the piece wouldn't stand upright - so it needed a pedestal - which disquise the piece's "topness" furter. The end of this serendipitous road.
More about this piece - and a link to its YouTube video at the attached link.
Any ideas for doing a Top piece - that doesn't appear at all to be a top?
Goya Top
Re: Goya+Aladin+Drozda = ? *LINK*
Jesper, Denmark
Re: Charlie......
Jesper, Denmark
Your posts so often end up making my day. I'm always wandering what the Dickens you will think of next?
BTW, the instability of the tall spinning top is due to centrifugal precession. If you could find a way to add just a little friction to it, it would react to stop the wobbling.
Re: Charlie......
charlie belden
A bit of surprise, followed by a smile is a nice goal for a piece ; )
As for wondering what's next - me too! Often one things leads to another - the end result not clear until well into it.
Would be easy enough to add some friction - a small concavity turned in the bottom of the pedestal a tad smaller than the ball bearing. But I think the problem with this one is that the bearing is a smidge off the vertical centerline on the piece
