A much better bowl turning video *LINK*
Notice the shavings on his hand instead of the dust that was on the other guys hand. He's using both pull cuts and push cuts. Notice also instead of trying to true up the outside he started truing up one area and then progressed from that area into the out of round area. This is much easier on your body because the trued up area gets bigger each time.
I also like that he points out that you should be watching the shape instead of the tool itself.
http://www.youtube.com/watch?v=-8J4xcOd6QU&feature=feedrec_grec_index
Re: A much better bowl turning video *LINK*
robo hippy
Pretty good, but he didn't core. Dare I say shameful! Just joking.
robo hippy
Ralph Lindberg
Actually Robo, while I am certainly not up to your level of coring. I find I can now remove the regular tool rest, put in the gate-rest. Select a blade, attach it to the handle (if needed) and take a core out of a bowl. All in less time then it takes me to turn the inside into chips.
I have gotten to where I core just about everything. Even if the core is not valuable as a smaller bowl, I can still toss it on the pile and burn it. :D
I'm actually considering coring everything for a while just for the learning process. The only problem is I don't make many larger bowls. My thought was, if you core out just one section and you care about saving it you will be more relaxed. Your not worried about the shape or cutting through the bottom etc. Just pick a cutter and try to produce the shape you want. Once it's out you can go back to making the bowl you started. A few dozen of these and you should feel pretty darn comfortable with the tool. Now I've just got to find larger wood.
Dick Wilson
John, You are right, this is a much better video. He first of all uses sharp tools. Other things I notice are his hand positions on the tool, the way he uses his body. The only thing I always do differently is employ the tailstock when putting the turning in the chuck.
Once the video is done YouTube gives you other options of videos to watch. There is one on turning a maple bowl. I watched it and saw this turner use a Termite tool. For those of you who have one and have problems with it clogging with shavings like he did I have a hint. The Termite tool is basicly a funnel. This guy was cutting using the top of the funnel forcing the shavings into a narrow opening. Turn the tool around and use the bottom of the funnel......no clogging :) :)
I know a couple of people who have been fustrated with this tool because of the same problem which is why I bring it up. Sorry if I am pointing out something that doesn't need to be said. Happy turning. Dick
Bob Macgregor
John,
Maybe you just need a lot smaller corer? If you keep turning things that need a dissecting scope to see, even a 1" corer might be 'way too big!
BOB
Dick I also noticed he stayed out of the line of fire as much as he could. I have watched the video of him using the ring tool. That is why I switched to hook tools. They don't clog. The termite is great for dry wood although I've switched to the Hunter tool where I used to use the Termite.
Mike Stafford
Mike Stafford
I think Mr. Palmer did a great job. I wish I had had access to videos of this quality when I was "self instructing" and maybe my learning curve would have been shorter and maybe I would not have made so many mistakes.
Say what you will about the internet, good and bad, there are wonderful resources out there to help crafters of almost any sort to learn how to do things correctly. And without forums such as Wood Central a lot of these resources might go undetected. I learned a lot after I found Saw Mill Creek, Wood Central and several other sites that finally helped me enjoy woodturning so much more.
No Face Shield!
Mike Brazeau
