Bit the bullet on a 20" bed extension ...
for my Jet 1642 EVS.
I've never seen the bed extension before. Does anyone have any experience with one? Does it hang off the end or what?
Re: Bit the bullet on a 20" bed extension ...
Not sure about that one, JL
You might have to build some kind of angle bracket on the end of your lathe to hold up the outboard end of your extension.
Jorge Casta�eda
In most of the big lathes, the extension is cantilevered, but you could rig some legs for it.
Jeff Willaford
The extension on my DVR does and seems to work fine for me but I don't know what Jet recommends. They show the extension hanging off the end of a 1236 on their website.
Somewhat definitive answer *LINK*
Found a "manual" for the BE-20 by searching the web. Couldn't find it on the Jet website.
So it looks like legs are not necessary.
BE-20
I'm pretty sure it's the same as my Powermatic but a little smaller. It attaches to one end with no legs hanging down. I put mine under the motor end so that when I don't need it most of it is under the motor and out of the way. I did have to turn the headstock around because my older 3520 was only tapped on one end of the bed to receive the extension.
I am planning to drill and add some metal on the leg so I can lower the extension on the tailstock end so I can turn much larger pieces. Or at least one piece hand mirrors where the handle is swinging about 21" which is just a hair bigger than my lathe can handle.
