DustRight DC fittings
Carole Valentine
Not long ago I finally purchased a "real" dust collector and found that fittings for various machines were a nightmare - there seems to be no reasonably tight standard among manufacturers, especially when it comes to quick connect fittings which would drop off if you looked at them even slightly crosseyed. The long hose was also a pain (No, I have not gotten around to running duct work - someday - maybe...)
Anyway, in desperation, I tried the DustRight fittings from Rockler and the expandable hose. The connectors are fantastic - a rubber boot with a clamp that gives you a secure seal on any port. Swivel connectors at the DC and the opposite end of the hose prevent any twist. The hose expands from about 4' to about 28' so I can reach anything in the shop without moving the DC, yet when it's "home" at either the bandsaw or the lathe I don't have coils of hose lying around. I won't go into all the fittings available, and they are more expensive, but suffice it to say that if you don't have ducting and move your DC from tool to tool, you might want to take a look at this system. It solved multiple aggravations for me.
And no , I don't work for Rockler, just think it is a good product that solves a common problem for the small shop.
