Home to Roost
Home to Roost
Home to Roost
Terry Scott
This piece of Olive was one of my entries into the Plain Bowl category at the Royal Easter show
Gaining a first
The olive came from Cornwall Park, trees planted by sir Logan Campbell 110 years ago.
Were the Easter Show is held in the Logan Campbell centre the land was donated to the city many years ago. This year was the 100th year of the A an d P show
You could say my bowl has come back to roost
Unfortunately it is very rare to source a piece of timber from the park as all the tree work and care is undertaken by contractors who in turn employ tree surgeons to attend to any trees that need attention . Many of us have tried the box of beer trick to no avail as these sods just keep cutting the wood into blocks fire wood. Its usually disposed of even before we hear about it .I was fortunate to be driving through the park and snatched it from under the nose of a park ranger
This category was made harder this year as the rules were tightened up, well harder for me as you know I don�t do plain
150mm dia 6 inches 80mm 3 � high 2mm thick
With my trusty glue stick I was able to double check that the curve was true
The photo doesn�t do the wood justice and it was like butter to turn, I was able to sand with 400 grit to 600 grit and nothing else
I hope the bowl doesn�t sell (all items have to be for sale )as id like to present it to the Cornwall park trust to sit beside another bowl I was commissioned to make for the Visitors center from the historic Monterey Pine that was cut down by Maori activists http://www.cornwallpark.co.nz/ http://www.cornwallpark.co.nz/index.php?s=2
Maybe Ill keep it a little while as this is soothing to the sole to hold .Light as a feather and only feels how olive feelsand smells cool smooth and strong all at teh same time
The Rules
Yes the rules were re-written as I was one of the entrants that always pushed the boundaries of the rules to the limit.This time a bead is even seen to be decoration so took a risk with the rim detail
Class 33 Plain Bowls
Wooden Items which have been turned to a bowl shape with all surfaces having been cut and finished on the late .No Detailing, decoration, coloring, texturing, embellishment or subsequently re shaping with other tools
There is no size prescription
On Monday go to www.naw.org.nz and the prize winners will be posted
Re: Home to Roost
Re: Home to Roost
Ronny Eelen
Terry,
This looks great. And congratulations to the winner.
Too bad it does look this great, it will sell for sure. Even if you don't want it to. Maybe you should put a fishy smell on it.
I like these shapes. As a matter of fact I am currently turning a large bowl, from a beautifull piece of Kaukasian walnut burl, which I would like to look like these. Being inspired by you, and trying to follow your tips.
keep winning
Ronny
Re: Home to Roost
Re: Home to Roost
Toney Robertson
Pretty wood and excellent form as usual.
"With my trusty glue stick I was able to double check that the curve was true " What is that trick? I am unaware of it.
Re: Home to Roost
Re: Home to Roost glue stick
Terry Scott
Have emailed you some pictures Toney
Cheers
Re: Home to Roost
Re: aw come on share with all of us
Steve Criscenzo
We want to know the glue stick trick as well. Great piece Terrry, Congratulations.
Steve
Re: Home to Roost
Wonderful
Maybe WoodCentral's next contest should have a "plain bowl" theme. That sure is one nice piece of olive, Terry. Congratulations on another prize winner.
Re: Home to Roost
Terry Scott
Get yourself a new hot melt glue stick
lay around the curve and because of the circular stick light refracts and you can easily see any bumps or hollows
Unlike a steel ruler that follows the bumps
inside or outside still works a treat
Re: Home to Roost
Re: Home to Roost
Vince Welch
i terry,
I love that shape. Nicely done and the finish seems perfect... very nice sheen.
Vince
Re: Home to Roost
Don Leydens
Re: Home to Roost
Don Leydens
Terry does plain? Did something freeze over?
I love the form as well. Perfect. I suppose this is close to being called a hollow form too. Always pushing the envelope somehow! Well done and congrats!
