Open the link below and watch a demonstration on the proper way to use a skew chisel. This is a very unique way to use the skew and I would expect that everyone here at WC will quickly become proficient in the use of this tool if they see this video and utilize the techniques demonstrated.
Re: A demonstration of the proper way to use a ske
Don Orr
Wow! He turns better with his feet than I do with my hands-and in softwood. And WAY more coordinated. Left foot tailstock lock and right arm power using the skew lefthanded/rightfooted. Whew. I can barely use any tool left handed. We are so spoiled.
Nice sharp tool too.
Re: A demonstration of the proper way to use a skew.
Vince Welch
THAT was incredible!!! Was that a Thompson skew?!?!?! Just another great example of how to use the skew! I would like to see how he sharpened that skew. I would think it would be fast and straight forward. Again really neat!!! I think I need to send him some sand paper samples... Vince
dick gerard
Did anyone else notice that the skew was very thin and the actual bevel was really long in relation to the thickness of the blade? In our world the guidelines are that the length of the bevel is about twice the thickness of the shaft. His must be 8 to 10 times the thickness of the blade.
Dick I noticed that the first time I saw this video. His sharpening angle must be 25 degrees or less, bevel to bevel. That's a carving tool angle. I have noticed that the foot powered lathe people use sharper angles than us powered tool people. When I did a 3 day demo on my pole lathe I reground my rough out gouge to about 35 degrees and it really made a difference in how much wood I could remove. As you can imagine the forces against the tool are much less with a sharper angle, consequently it takes less leg power to remove the wood.
Doug Trembath
Like the difference in tool geometry, the forces present with a bow lathe are far different than in a powered lathe spinning continually. It's a lot easier to have problems with the tool when the work is constantly spinning, allowing an uninterrupted cut. The speed of the work is also radically different, making his work easier to do, and he obviously does it well. Think you could use your feet the way he does all day, every day for a living? He supports the "Tail" stock with the left foot as well as aiming the skew with the right one. I've been in a number of less-developed countries, but have never seen anything like this approach. What a wonderful thing the Internet is, huh?
You'll also notice that the skew was only slightly angled, making it much more like a chisel. I've used a flat chisel as a turning tool, probably like many of you, as an exercise, and if handled properly, it works well. There was obviously a reason that the skew came about, though, and I do prefer the skew, personally.
R Henrickson
I seen pictures of the same setup and techniques being used by a traditional woodturner in Cairo, though given the publication date of the book and when the research might have been done, that turner may have been working 20+ years ago.
R Henrickson
Also in a book on traditional crafts in Iran, pictures of an itinerant woodturner shows a similar lathe, though the turner seems to be holding the skew without the use of his foot.
